Active Member
![]() Join Date: Dec 2007
Which Accelerator Pedal?
The cab on my 70 C10 does not have holes for the ball studs for the accelerator pedal. This leads me to believe it is a late 70's cab. I currently have the linkage for a pedal that mounts to the floor.
Would I be better installing the ball studs or switching to the 71 accelerator assembly? The engine has a Sniper EFI and a TH 400 transmission with a Lockar kickdown switch. Thanks |
Re: Which Accelerator Pedal?
By far the later floating pedal unless you are looking or something that looks original.
![]() Join Date: Feb 2022
I just installed a application where a bell crank was used for throttle. Connecting to the 1972 pedal was so simple it was almost disappointing. No thought or effort needed.
![]() Join Date: Apr 2016
There is a hybrid approach that I plan to use, 71/72 style floating pedal on earlier throttle setup. https://67-72chevytrucks.com/vboard/...40#post7871640
![]() Join Date: Jul 2003
The 1971/72 cable system was far superior over the 1967-70 rod system.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Not ideal , but I took the pedal off my '69 many years ago . Seems to work fine without it .
