Today, 10:31 AM | #1 |
Heater blower ?/problem
Working on 68. Heater blowermotor does not work. Replaced motor, resistor and fan speed switch. Fuze and ground are good. I have power to connector that plugs into blower motor. Still doesn't work. What am I missing ? Tks in advance
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom) 1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK. 1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive ! |
Today, 11:05 AM | #2 |
Re: Heater blower ?/problem
Do you have a ground wire in place on the motor and does it have a good connection?
Today, 01:01 PM | #3 |
Yes good ground. Shouldn't the motor run with unplugging hot wire and running a wire straight from batt. + to blower motor ? Grounded of course.
Today, 01:10 PM | #4 | |
I wonder if your fan is jammed somehow inside the housing preventing it from rotating. |
Today, 01:46 PM | #5 |
With jumper wire on both pos n neg from battery to motor it still doesn't run. Second "new" motor thinking 1st one could be bad. Both these new motors and the old one do not run when hooked directly to 12v(battery)
Today, 01:48 PM | #6 |
See if it will run when removed from the heater housing.
Today, 02:04 PM | #7 |
Nope. Does not work holding in hand hooked up directly to batt
Today, 03:06 PM | #8 |
Wow. That's crazy. Is the motor housing made from multiple metal segments? If so, try grounding the individual segments.
Today, 03:29 PM | #9 |
Ok tks. I'll move ground around. At this point I'll try anything !!!!!
