Old 08-20-2024, 09:40 PM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
LS Information
Looking for a donor LS for my 72 2wd Blazer. I really have no idea what I should be looking for. 5.3,6.0,6.2 and also what transmission I should be looking for 4L60E, 4L80E , 6l80E. I have looked at quite a few adds for eng and trans complete with harness etc. I assume i want the lowest mileage i can get and I don't want a four wheel drive transmission. Is there a better year span or certain things I dont want. Price is not really a selling point if it is more complete. Lots of questions for anyone that has answers.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 08-21-2024, 12:34 AM   #2
mongocanfly
mongocanfly's Avatar
Re: LS Information
to me the earlier yrs are a better choice...5.3 or 6.0, but low mileage, early yrs are hard to come by, the later yrs work, but have more of the crap on them that nobody wants
for trans a 4L60 is a 700R4 ,a 4L80 is a T400 w/od, id try to get a complete engine/trans from the same vehicle...itll make life simpler
if you want dbw be sure you get all the pedal assembly
if you have room ,it may be best to by a whole wrecked truck to harvest parts from, but no necessary,being able to hear it run before buying is a bonus
for a harness if you use a aftermarket harness ,the factory one wont matter, and ive never gotten a uncut harness with any of the engines ive bought, but i use PSI, BP is another good harness
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-21-2024, 09:13 AM   #3
Willie Makeit
Willie Makeit's Avatar
Re: LS Information
very very few low mileage LS motors left out there, GM has been using the LT platform for the better part of 10 years now (2014). Summit now sells a Gen 3 450 hp 5.3 for $3,800. In my experience you'd be hard-pressed to rebuild a high mileage 5.3 that makes 450 hp for that amount.
https://www.summitracing.com/parts/s...rxcZ_eaxCKUpVr
Willie Makeit is offline   Reply With Quote
Old Today, 01:56 PM   #4
Accelo
Accelo's Avatar
Re: LS Information
The wiring is much more complicated for the LT platform. Fuel pressure is also higher.
The transmission that correctly talks to the ECM is also limited. Even the 4l60E has an additional sensor in the pump that has to be present and connected, i.e. the pin count in the plug is different. The wiring harness is more expensive. In fact, everything costs more for the LT series.
For these reasons, I prefer the earlier motors. They are excellent motors and will run a ton of miles before requiring any machine work. Get any matching motor and transmission and go after it.
Accelo is offline   Reply With Quote
Old Today, 02:14 PM   #5
Lokin4AReason
Lokin4AReason's Avatar
Re: LS Information
i have one in my daily driver
its oke but would i put in a older model vehicle , nope
much rather the older block(s) n transmission(s)
ls a large amount of headaches
wiring , fuel lines , and running everything
once everything is in , sorting out the code(s) and sensor(s)
if that isnt resolved , wont run right
minute my vehicle is running , junking my truck
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
