Old Yesterday, 04:16 PM   #26
panhead59
Re: Heater blower ?/problem
Pic of washer
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom)
1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK.
1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive !
panhead59 is offline   Reply With Quote
Old Yesterday, 04:32 PM   #27
pjmoreland
pjmoreland's Avatar
Here's a thread that discusses the issue.
https://67-72chevytrucks.com/vboard/...d.php?t=817625
pjmoreland is offline   Reply With Quote
Old Yesterday, 04:50 PM   #28
panhead59
Tks. I figured out that the square washer went on first. I had the cage on. Upside down !!! So u were right. Flipped it over and checked for motor operation. It spins while hooked directly to battery. I'll pick it up in the morning. Tks again
Old Today, 11:59 AM   #29
panhead59
Reinstalled heater motor. Worked with jumper wire to battery +. Rehooked batt to truck. System now works as advertised with one exception. I have an open circuit from fuze box to connection to on_off and fan speed switch. Brown wire I believe. So I hooked up temp wire from heater fuze to switch. Works fine. So what open fuze spot would be good to connect wire permanately ? I don't want to leave it rigged with just the wire behind fuze.
Old Today, 12:19 PM   #30
pjmoreland
pjmoreland's Avatar
Do you have a good 10A fuse installed in the slot labeled "AIR COND."?
Old Today, 12:31 PM   #31
panhead59
I do now. One in there was blown
Old Today, 12:35 PM   #32
pjmoreland
pjmoreland's Avatar
Do you have power on the stock brown wire now?
Old Today, 12:52 PM   #33
panhead59
Yes sir
Old Today, 01:14 PM   #34
pjmoreland
pjmoreland's Avatar
So everything is working now?
Old Today, 01:29 PM   #35
panhead59
Yes sir. Thank you very much. Tks for sticking in there with me till the end !!!! If I can ever return the favor I certainly will !!!
Old Today, 01:30 PM   #36
panhead59
All this started with me just checking things out on truck to prepare it for sale. Now I can proceed. Tks again.
Old Today, 01:32 PM   #37
pjmoreland
pjmoreland's Avatar
I'm glad you were able to get it working.
