Rough idle- low vacuum
So I got a 1972 K5. It always had a bit of a rough idle. It bugged me and so eventually I swapped out the engine for a new crate 350 from Blueprint. The only parts I didn’t swap were the intake manifold, the carburetor, and the distributor. But the new engine still had a sloppy idle. The kind that is slightly inconsistent, that throws the timing light off every so many bleeps. Anyway… since then I’ve swapped the carburetor (for another same Edelbrock 1406,) swapped out the distributor, taken out and reinstalled the intake manifold, studied the carb in depth and learned everything about tuning it, and hunted down every possible place I can think of for vacuum leaks (around the intake manifold, base of carb, surface of intake, valve covers, disconnected any and all hoses and lines including break and transmission,) and yet… rough idle and vacuum at 15 jumping around a bit as it sputters. When I accelerate it sounds and runs great. But to keep it from dieseling I have to run out the air mixture screws 2.5 turns. I set my idle rpm at 800. What else could it be?
Re: Rough idle- low vacuum
Lack of enough initial timing!
What’s your timing set at? Set your idle at 700 for checking and with vac advance plugged off. |
Initial timing set at 15 advance. I don’t use vacuum advance per engine manufacturer recs so it’s plugged
Yup!
I’ve seen that before. Plugging in your vac advance for testing won’t hurt a thing. Nobody will know. Give it a shot. |
An 800 RPM base idle setting will cause run on (dieseling) when the ignition is turned off.. Unless you have a cam that has a lot of overlap, the idle speed should be about 600 - 650 at the most..
The air fuel mixture screws are for adjusting the idle mixtures not idle RPM.. You seem to be concentrating on the search for vacuum leaks.. There are a million things that will cause rough idle conditions.. These are only a few. Spark plugs fouling from overly rich condition. Faulty distributor cap, rotor, and/or plug wires.. .. Not to mention improperly adjusted valves and/or timing.. You will have a difficult time obtaining a suitable tune with not having vacuum control advance on the street. Never mind what the "specs" are.. Give the engine some settings that it likes... You may not like the following: I'm just not a fan of Edelbrock carburetors. They, too often, cause the very problems you're having.. |
Thanks RustyPile. I am aware that 800 is high, however the idle is too rough when I lower it. You are correct about the air mixture screws, but adjusting the air to fuel ratio at idle will also impact idle rpm, so enriching the idle means readjusting the rpm back down. Spark plugs are new and gapped, wires are new MSD (been through plenty wires and spark plugs which haven’t resolved this issue.) I’ve adjusted valves. Distributor is new as well. Have replaced just cap and rotor in the past. I’ve addressed everything on your list and issue still happening. Keep in mind that it was happening on my previous engine as well, so that says a lot. As for vacuum advance… the engine runs fine. It’s just the idle that is the issue, and the idle would be getting anything if from a vacuum advance.
You swapped the engine for a rough idle?
This sounds like a classic vacuum leak to me so I think you're on the right track. There are definitely many other potential issues worth a look, but I'd chase those all the way down. Double check for any un-plugged fittings and check EVERYTHING that has vacuum in it - note that even the transmission vacuum modulator and the brake booster can be a source of leaks. My usual approach is to plug everything at the source, then use a little starting fluid or carb cleaner to check the manifold and around the carb. +1 on no vacuum advance on the street being a Bad Idea - giving up power and fuel economy... |
So I did unplug the transmission and the vacuum lines on the intake, as well as the break booster on the carb. I plugged them all. I sprayed carb cleaner all around and got no change in idle. I’ve done this many times, never any change. About to unplug the PCV valve run a vacuum gauge there (plugging the breather on the other side) to see what internal info I get there. But tired of this nonsense lame idle.
And willshook, I replaced my engine cause I was having a bad hair day lol.
Jk. Have confidence that you’re not dealing with an idiot here. It was an old engine that had bad compression. My point was that the idle issue was occurring on the old one as well… |
Your biggest vacuum loss is how open your throttle plate is to get an acceptable idle.
Can you tell me more Geezer? My understanding is that opening the idle screw (CW) will open the throttle plate and increase the idle. If that is the case, than closing the screw reducing idle RPM, and then feeding it more gas with the idle mixture screws would fix that, right? Currently my idle mixtures screws are out 2.5 turns, which seems like a lot to me. Can you explain further?
![]() Join Date: Feb 2016
Did you reuse the same balancer and timing tap from the old engine on the new one?
If so I would verify the accuracy of the TDC marks. It's a good idea at this point anyway as it may help you to figure this out. Here's a video by someone I respect on the subject that may help you troubleshoot the issue you're having. https://youtu.be/DpU7pV4Li3A?si=qwlG1t8aHHILOliB
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; Yesterday at 02:28 PM. |
#13 | |
![]() Join Date: Apr 2016
Depending on how many degrees of advance your vacuum can gives you may need to set the advance to less, perhaps initial between 4 to 7. Take it for a drive with your new smooth idle and smooth engine, and see if you get knocking, then you'll know to turn the advance down. But leave the vacuum advance connected to manifold vacuum when you take it for a test drive. |
#14 | |
#15 |
Do any of your spark plugs show signs of oil?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#16 |
#17 |
HO455 the spark plugs look perfect. And the trucks runs well, though gas mileage is low at 8-9mpg. Should get more from a newer crate engine.
The issue also become more pronounced after the engine warms up and then sits for a minute, which makes me suspect vacuum leak somewhere due to expansion. But I just can’t seem to find a source. |
#18 |
If you had the same problem with two engines I suspect something else is causing it . How old is the BluePrint motor ? I installed one in my 72 this spring have 5k miles on it not one issue .
Also the engine was run on a dyno so no fiddling with the carb or distributor should be needed other than maybe jetting for altitude. Mine was pretty much plug and play
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#19 |
![]() Join Date: Jul 2008
"The only parts I didn’t swap were the intake manifold..."
Just throwing this out there - if you're having the same issue between the two engines, consider parts that were carried over, maybe look for a cracked/warped intake manifold. Good luck! |
#20 | |
Just throwing this out there - if you're having the same issue between the two engines, consider parts that were carried over, maybe look for a cracked/warped intake manifold. That was the driver behind my question about the plugs. It's possible that there is a porous or cracked area in the intake manifold. If it was in the valley it is likely that you would see oil on the plugs. It could also be between the exhaust cross over and intake port. Are you running a factory cast iron manifold or an aluminum aftermarket one? Are you using a carb adapter to bolt the 1406 to a spreadbore manifold? As I mentioned earlier a bad balancer would cause you to set your timing incorrectly. Try setting the timing for best idle (Ignoring the actual numbers.) and then try adjusting the Idle set point and mixture.
