Longhorn cut down to short box
Has anyone ever done this yet ?
All about them K’s
![]() Join Date: Jun 2014
Re: Longhorn cut down to short box
I’m sure someone has but can’t for the life of me imagine why someone would. That longhorn is a real truck, built to work its butt off day in and day out.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
I've never done it, nor seen it done.. I wouldn't advise doing it for two reasons -- (1) bad idea, and (2) bad idea... OK 3 reasons.. (3) As Taskforce said -- It's a real truck, built to work, not parked in a space at some car show...
Who Changed This?
![]() Join Date: Jan 2013
A Longhorn has a 1T frame. It rides hard already, unless loaded. Shorter would be worse, and what would a C-notch look like? I have so many questions about why.
You most likely wont find the answers you are looking for here. This place is great, but tends to lean more to the preservation or stock side of things.
If you have InstaGram reach out to @classic_chev, he does a lot of boxside shortening and may be able to help you. He’s also a member here, but for the life of me i can’t remember his handle.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
all i could say , if you want a short bed
sell the truck and buy a short bed at where you start from not to many longhorn(s) out there . . .
dont want to hear excuses, i want to hear solution(s) |
![]() Join Date: Feb 2002
Ouch.
Does the OP intend to swap the suspension for that of a half ton? If not, anyone who sees it will know it isn't right.
I'd also agree that longhorns are somewhat rare if not terribly desirable. Why hack one if you don't need to? |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
The why is in his user name. He is obviously looking for a way to throw away or burn some of that excess cash. That's the only possible reason.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
At the body shop.
Excuse me, some of your purist maybe showing.
My favorite is the C20 made into a K5-
" That didnt make it any newer " " Dont antique the equipment " |
#11 | |
While I wouldn't cut a 'Longhorn' down to a shorty for the exact reason it is a Longhorn (the rare, longer than standard LWB HD frame & extended long bed), there are plenty of guys building HD 4x4 Blazers on SWB length frames so it's entirely possible someone w/the right skillset, vision, & bank account could pull off a bad-arse build of one. In a nutshell..... Do it if 'ya want. Don't like the idea? Provide respectful info advising why it shouldn't be done. Beyond that, if you don't have anything nice or constructive to say, don't say anything.
![]() Join Date: Dec 2014
I agree that the guy just asked a question, no need to ridicule.
Maybe the Longhorn is a wreck and whatever he has planned will save it from being crushed: who knows. I wouldn't do it, but I would admire the craftmanship if it were done well. As hypotheticals go, it is definitely the first time someone has asked the question, on a forum with about 10 million posts.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
