Old 12-20-2017, 06:50 PM   #1
rice square
rice square's Avatar
1986 GMC SWB Autocross
Hello all, new to membership but I've been using the forums since I got the truck back in '14. I bought it from a classic car dealer out of Houston on eBay auction; it had been his daily. It had been moderately restored and had a LT1/4L60 swapped at some point before the guy I bought it from purchased it.
rice square is offline   Reply With Quote
Old 12-20-2017, 08:56 PM   #2
SKT
SKT's Avatar
Re: 1986 GMC SWB Autocross
Good looking solid truck - tell us more!
I saw your other post from:
http://67-72chevytrucks.com/vboard/s...postcount=1266
Originally Posted by rice square View Post
Hello all. I'm a new member but a long time lurker. Here's my '86
Oh, and we like lots of pics around here!
SKT is offline   Reply With Quote
Old 12-20-2017, 10:04 PM   #3
Billy81
Billy81's Avatar
damn that is one sharp looking truck.
Billy81 is offline   Reply With Quote
Old 12-21-2017, 12:39 AM   #4
rice square
I wasn't happy with the interior so that is where I started. It had really poorly placed 6 1/2" speakers in the doors and overall most of the interior needed help. I replaced the carpet in the factory charcoal color, added new black door panels with accesories and replaced the cracked dash with a new black dash. I then relocated the door speakers to the kick panels, and added two 8" subs with an amp behind the seat. I also replaced the dated single din with a new Alpine head unit and replaced the blown out 6x9s in the rear corners. Next, I swapped all of the interior lighting to led, and added some desperately needed cupholders.
Old 12-21-2017, 01:00 AM   #5
rice square
Next big change was lowering it. The 1st setup I had was a 2" coil up front and 1 leaf removed in the rear; I loved the stance but it was way too bouncy in the back. At this time I believe I added the C30 sway bar; mine did not come with a sway bar from the factory. After getting fed up with the bad ride, I got a flip kit and added the leaf back in, and replaced the stock shackle with a 1" lift shackle. At that time I got a Suburban/K5 rear bumper for a cleaner look. I was pretty satisfied with the ride and looks so I kept this stance for about 2 years.
Old 12-21-2017, 01:01 AM   #6
SKT
SKT's Avatar
Did you follow the Cannonball C10 build?
http://67-72chevytrucks.com/vboard/s...d.php?t=602304
Old 12-21-2017, 01:11 AM   #7
rice square
Now we're in '17. This year I replaced the front shocks with QA1 adjustable shocks #SR2254P, which I found to be almost identical specs as the stock shocks, but with the ability to keep the truck planted and confident in turns. Around that time I tinted the headlights yellow with Lamin-x pre-cut tint. In June, I finally got around to ordering the CCW Classics, which had been on the top of my list of things I wanted since before I even had the truck. I'll post the wheel specs in a picture below. Since I stepped up to 17s with a little less aggressive fitment up front, I had room to run drop spindles and not rub, so I lowered the front 2.5" more, and lowered the rear 1" by swapping the lift shackle back to the stock one to a 4.5"/6" drop. I finally got the center caps in today so the pics posted here won't have them on.
Old 12-21-2017, 01:16 AM   #8
rice square
Wheel specs
Old 12-21-2017, 01:21 AM   #9
rice square
I am a part time college student and full time worker so progress has been slow on the truck. It's the first vehicle I've owned and my only 4 wheeled vehicle, so I haven't been able to start digging into the fun stuff like IRS, race buckets, 6spd MT, etc.
Old 12-21-2017, 01:22 AM   #10
rice square
Originally Posted by SKT View Post
Thank you for the kind words! And yes I have been following that build, one of my favorites for sure and definitely a big influence on my build so far.
Old 12-21-2017, 01:28 AM   #11
rice square
Oh, almost forgot. I ripped out the Flowmaster 50s and replaced them with Dynomax race bullets. Long tubes into the bullets with no crossover pipe= pure racetruck at WOT. I have to say LT1s have one of the best exhaust notes in my opinion.
Sound clip
https://youtu.be/JT4IQFcPhAA
Old 12-21-2017, 06:05 PM   #12
Barbecue
Beauty! What year is the LT1?
Barbecue is offline   Reply With Quote
Old 12-21-2017, 09:23 PM   #13
rice square
I'm not 100% sure if I'm being honest. It has the optispark vent that comes from the air intake so I assume it is a later model motor. I have the vin of the car it came out of but I've been too lazy to look it up haha.
Old 08-22-2024, 01:38 PM   #14
rice square
7 year update from the dead:
The oil pump on that LT1 died and the gauge seemingly failed at the same time, long story short the motor was wiped and I opted to stick with a Gen 2, albeit a 383 short block LT4 buil by Golen Engines. I reused the cam, valve springs and pushrods from the old engine, and acquired a set of Camaro heads and Crane 1.7rrs. Throughout my ownership of this truck I've fought with finding a reputable tuner, as LT1s are old news at this point. A company called TorqHead came out with a bolt in solution to convert LT1s to coil on plug with an LS 411 PCM, which on top of being a much more reliable system makes it infinitely easier to find a good tuner. By the 3rd time I liquefied a 4L60, I made the decision to swap to a T56. Through lots of research and R&D, I went the opposite direction that most people have gone and adapted a LS-style T56 to work behind the LT1. Around that time I added a rear sway bar and a set of traction bars.
Old 08-22-2024, 01:41 PM   #15
rice square
Update photos:
Old 08-28-2024, 02:38 PM   #16
Android04
Android04's Avatar
Sweet build
Android04 is offline   Reply With Quote
