![]() Join Date: Mar 2005
Center AC Vent Mod
I finally got everything hooked up and working, except the AC itself. I did the center vent mod which only uses 1 inlet hose. Not really working out. It blows a good amount of air to the driver, but none to the passenger. Side vents work as expected.
Guess next time I take the dash apart, I'll put the dual feed housing back in.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
Re: Center AC Vent Mod
Thanks for the info, I'm putting together a collection of AC parts and will keep this in mind.
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
I did mine that way too, didn't bother me too much since nobody sits in the middle.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
I'm mulling over the same thing, I'm an A/C hog, I always turn the vents toward me (selfish huh!) So I'm thinking this might work out in my favor?
It greatly improves the airflow to the driver, nice when it's really hot in the summer. I just did it that way to simplify the air hoses in the dash, but it does have a side effect.
I plan on getting my AC working prior to summer. If I want my wife to ride as passenger I must do all I can to keep her cool. So, I'm going back to the original setup. You know what they say... Happy wife, happy life!
![]() Join Date: May 2012
I did the mod because of limited space behind and around the original AM radio. I hated the Mod. I installed a retro sound. Now there is enough room behind my dash to park a bus! I re-plumbed center vent to blow out evenly, much better that way. But, hose wrestling around the stock radio is no fun either.
White K20 |
Old member
As long as cold air is blowing out the center vent who cares! It blows straight out no matter how it's ran!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#9 | |
Moderator
![]() Join Date: May 2007
![]() Like Andy said, cold air is cold air. If the AC works that's all that matters, the cab will stay cool no matter how the air is directed.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Old member
Center vent.
Outside temperature!
This is not correct.
White K20 |
Old member
So your saying it doesn't come straight out? Mine sure does. The air comes into the center vent from the side one are the other and hits the other side then comes straight out the vent looking at you.
But I really don't see how it's not enough cooling to begin with when you haven't changed the capacity of the unit. All you have done is restricted the flow. ![]()
![]() Join Date: May 2013
If you dont smoke just put it where the ash tray is , Im sure someone has done this on a retro ac install
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#14 | |
If you do the mod of the OP, which is the mod I did. Plugging one hole and using one hose, then the air flows in the direction the single hose is pointing. It's a dysfunctional mod. I did not like it. I agree, do you get enough cooling in the cab after a bit of time running, but the passenger gets no air from the center if you only hook up the right hand hose, which is the easier hose to keep hooked. Right had hose only, then, the passenger gets no air from the center. And if that passenger is your wife on a hot day..... then you move toward reversing the mod! ![]()
White K20 |
#15 |
Old member
I've had this mod for several years at least 10 and have never had any problems with it. My wife rides with me a lot and has never complained about being hot. Temp wise anyway!
#16 | |
White K20 |
#17 |
I run Vintage Air with my stock center vent with the single hose set-up with the driver side inlet plugged. As mentioned, all flow is directed to the driver. However, I seem to recall that someone was making modified plastic ducting for the center vent with a single hose inlet to fix this issue. I think it might even be Vintage Air.
After some research, I found that it was Brother Truck that has them. https://www.brotherstrucks.com/67-72...tinfo/CVUG072/ Its still a side inlet, but it looks like the plenum is contoured with a 90 degree bend to push the air straight out the vent. Last edited by cleszkie; 01-09-2017 at 02:31 PM. Reason: more info |
#18 |
![]() Join Date: Jul 2012
This is what I am going to use,came from restomod air. My inside unit(also restomod air)has 2 outlets for center vent but I will be blocking one off.
#19 | |
I also see brother has this one https://www.holley.com/products/ac_a.../parts/CVUG072 does it help? On my vintage air kit. You block off one side of the inlet (driver side). But on mine all the air is directed to the passenger side.
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
