Old 08-28-2024, 08:52 PM   #1
Ziegelsteinfaust
Seafoam usage
As I mentioned before I killed my last LT1 350 by dropping a bit into the intake. So it was replaced by a iron head LT1 from a Caprice to which I swapped on factory aluminum heads. It looked perfect from the outside, and when I got it. Did fine on a leak down test.
When I started it up after installation. I had a pronounced puffing out of my oil full from blow by. I tried pouring a can of seafoam in the intake. Then with another bottle I put some in the engine, and the rest in the gas.
This cleared up about 1/2 the blow by. Driving the truck around 100 miles did n9t make a perceived gain. #7 cylinder still had 90 psi cranking pressure. With the rest around 180 to 200 psi.
So I order seafoam spray, and fogged down #7 heavily. This solved the problem. I have basically no blow by now or excess crankcase pressure. I will take it on a 200 mile drive this Saturday to visit family, and remeasure #7 cylinder.
So in my opinion. If your going the seafoam route for blow by. Just get the spray, and let it soak for a day or two. Spraying more in every few hours to deep clean.
Ziegelsteinfaust is offline   Reply With Quote
Old 08-28-2024, 10:13 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Seafoam usage
Call it what you want.
There are certain issues that I have used this.
Mostly in the Gas tank.
It is Very good Snake Oil.
This stuff has fixed several issues I have had with vehicles.
This is My Go-to for Fuel issues.
I believe in this and a few other Elicker's.
84 Chevy K-20
