Old 08-27-2024, 06:56 PM   #1
tutone
tutone's Avatar
Painting the inside of the bed
Recently, I have spent a heap of cash on the 98, and I want to ask you guys a question. It is all org, indigo blue (solid). The outside and interior could pass for a 5 year old truck. The bed though, is another story. I have used it as a truc, not abused, but the bedsides have several clearcoat scratches and a few small dings, nothing that cant be smoothed out. The floor has always had a rubber mat and the tailgate has a bedliner plastic cover on it.
Now if I take it to Line x, they will do a nice job, but do you think if I did that, would it be taken that I was covering up something? My other 2 choices would be, sand / prime /bc /cc. Or single stage mixed at the paint shop in aerosol cans. Body work is the same. What is your guy's opinion?
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1972 K10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71
tutone is offline   Reply With Quote
Old 08-27-2024, 11:27 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: Painting the inside of the bed
Honestly I would line-x it an not look back. My 98 has had it for 20+ years and has held up exceptionally well, hauling chord after chord of fire wood, trips to the dump, you name it. The floor in mine is pretty wavy from the firewood but the line-x hasn’t peeled or cracked at all. If you are going to use it as a truck I can’t think of a better way to go. I don’t personally look at a truck with a professionally installed spray in bed liner as covering anything up because the pro’s should take all the steps to make sure it done right so the warranty is valid. Now if Jim-bob and Cletus did it with one of the Walmart special roll on kits I’d be very suspicious.
Tyler
Old 08-28-2024, 11:59 AM   #3
tutone
tutone's Avatar
The premium shiny bedliner is 650 bucks. I pull in and out in a couple of hours. I sold my 71 and this one gets me into the chevy truck shows. It is by no means a showpiece but I still use it almost daily. A nice straight dent free bed might keep me from hauling anything. That is the reason for my inquiry.
:My build thread
Old 08-29-2024, 06:01 AM   #4
4u2nv
Can you not get Line x colour matched ???
Take the small dents out that you have , Line x it and you can still use it as you have been.
Covering something up would not be my thoughts if I seen it, it's all too common to see it done .
4u2nv is offline   Reply With Quote
Old 08-29-2024, 07:24 PM   #5
tutone
tutone's Avatar
Here is how they explained the color match over the phone. The actual liner is black and the top coat is the color match. So if you have a bad scratch or a peel spot, it shows the black bottom layer. It is 1350 bucks at our local dealer for the blue. For double the price of a premium black liner, I would just paint the bed.
Whatever I do I will post before and after shots of the truck on this thread.
:My build thread
