Old 08-21-2024, 09:51 PM   #76
IronCanine
I'm trying....
IronCanine's Avatar
Re: 1970 K20 Z62 Full Restoration
Originally Posted by jerry moss View Post
sorry I mentioned that part about the mirror, it just made more work for you that only some idiot like me would even notice. looks awesome so far.
Don't be. We are fully invested. It was a miss. There a lot of things to try and get right and it's not suprising that that happened. There was concern when we realized it, about welding to a closed space with sound deadener in there. No doubt your comment prompted a lot more discussion about should we and how should we. In the end, nothing caught on fire and it's a mistake we don't have to live with. Those boys working on that cab are good.
This board offers inspiration in many forms. And I appreciate it all.
IronCanine is offline   Reply With Quote
Old 08-22-2024, 03:10 PM   #77
1970cstblazer
1970cstblazer's Avatar
Originally Posted by IronCanine View Post
I would love to see pics of the oil fill tube. I was not aware that a valve cover oil fill tube was available in 70. I know a lot of us add the 71-72 oil fill tube to pre 71 trucks for the convenience. I did it on our 70 Blazer.
Here is the low mile 1970 K20 with 307 from BAT. This tube is 1970 only, as 1971-72 tubes have the rubber cap.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 08-22-2024, 03:43 PM   #78
IronCanine
I'm trying....
IronCanine's Avatar
If you zoom and enhance the BAT K20, it looks like the 71-72 tube and has the "OIL" labeled rubber cap (to me).
I don't doubt you. Super intrigued actually. Lot of little mysteries (still) to me with these 70s. So much one year only stuff.
Old 08-23-2024, 06:30 PM   #79
1970cstblazer
Red face Re: 1970 K20 Z62 Full Restoration
Right you are. Might be a late change. My March built Blazer has the steel cap, and the base of the tube is twist on.
Old 08-23-2024, 06:46 PM   #80
1970cstblazer
Arrow Re: 1970 K20 Z62 Full Restoration
After a thorough search, I have found the part number for the 1970 only K series with power brake booster oil filler tube. Per a June 1971 parts catalog, it is GM 3929746, and the part is stamped with this part number.
http://www.gmpartswiki.com/getpage?pageid=220375
https://67-72chevytrucks.com/vboard/...d.php?t=798420
Also used on big block medium duty trucks 1969-70 with 366 and air brakes.
Old 08-23-2024, 07:35 PM   #81
IronCanine
I'm trying....
IronCanine's Avatar
You have taught me something. Thanks! Bringing receipts! Nothing better than pics and part numbers. Love this group. Something else to chase.
Old 08-23-2024, 07:45 PM   #82
chewychevy67
The fun is in the chase. Your right though. This board has so much education in it if you know where to look. I spend more time on here researching most evenings than working on my build.
chewychevy67 is online now   Reply With Quote
Old 08-23-2024, 11:28 PM   #83
IronCanine
I'm trying....
IronCanine's Avatar
100%. I kinda thought I knew what I didn't know...cuz I'm actively chasing that! More that I don't know I don't know it turns out. I've already said it a couple of different ways in this thread. However good this truck turns out...it will be because of the help and generosity of information from the folks on this board.
Old Today, 09:09 PM   #84
IronCanine
I'm trying....
IronCanine's Avatar
Ok. Back at it. So the engine got run in on the dyno which was (thankfully) uneventful. They did a couple of pulls on and she made 288/385. Which is more than the factory rating. But you need not worry about those gaudy numbers. I'll get her back under control with stock exhaust manifolds and a sweet factory single exhaust. Wouldn't want this horse to throw me.
She went from the machine shop straight to Eric's for paint prep.
We got the clutch and pressure plate on. The entire rotating assembly was balanced prior to assembly including these pieces. Then the bell housing because it appears to me that the bell housing was on and "over sprayed" when the engine got painted. Clean up of this engine/drivetrain indicated as much. And Joe's low mileage K20 bellhousing has similar paint coverage
Also had to scrounge up a vac line clip since this engine came from a K10 and had TCS (which had to be deleted on this K20).
Old Today, 09:16 PM   #85
IronCanine
I'm trying....
IronCanine's Avatar
Hi temp primer and paint...
I should mention that Mike Cofield helped me find my date code correct water pump. Then he thankfully sussed it out when the "Dutchman" mistakenly sent my rebuilt water pump to him...that's a longer story than can be well told in one sentence. Needless to say Mike saved the day twice.
Thanks Mike!
Old Today, 09:22 PM   #86
IronCanine
I'm trying....
IronCanine's Avatar
Final paint this week and brought her home today. I threw a few quick pieces on just for fun. Unfortunately I've got a meeting out of town this weekend or I'd be fully dressing her out.
Old Today, 09:34 PM   #87
IronCanine
I'm trying....
IronCanine's Avatar
Again, we will not bat 1.000 on bolt heads and OE hardware in this build, but a lot of effort has been made to use the bolts that came on it or would have come on it.
Honestly it was cool to see that Joe's 71 and this 70 engine had the exact same hardware arrangement on the water pump. Two "C"s on the right and an R/S/C on the left. Confirmed to me I had what came on it.
Old Today, 09:38 PM   #88
IronCanine
I'm trying....
IronCanine's Avatar
The big win of the day was that thanks to Dave (DaHos), I hit big on a WTB in the parts section. He had one of the mysterious 1970 only oil fill tubes. No cap, but turns out there's a ton of them, NOS and pretty reasonably priced on eBay (considering what I've gotten conditioned to of late).
Thanks Dave!
