Old 08-30-2024, 12:01 PM   #1
pjmoreland
pjmoreland's Avatar
8k Tach Cluster
This is a very clean factory gauge cluster that was rebuilt and modified to add an 8k tachometer and a factory vacuum gauge.
This build addresses the following issues present in the reproduction 8k tach kits sold by the truck parts vendors. The reproduction lenses have the green background paint applied to the wrong side of the lens which causes the backlighting to be poor at night. The tach numbers on the reproduction lenses are poorly spaced and do not line up with the tach markings. There is also an odd-looking set of smaller numbers in toward the center of the gauge. The font used for the reproduction lenses is different than the factory font. The 8k tach kits position the tach too high so that it does not line up well with the hole in the tin and numbers.
This build uses all OE parts, with the exception of the 8k tach itself, a new circuit and a new bezel. An OE lens is used and has a custom tach decal applied that achieve an OE look.
Here are the details on this cluster:
Tach - Brand new reproduction, Counterpart brand
Fuel, Temp, Oil & Battery Gauges - These are nice OE gauges that have been bench-tested. They all function correctly. Needles have been repainted.
Speedometer - This is a nice OE unit. Tested by spinning it with a servo motor at precisely 1001 RPM, and it read 59mph (60mph is perfect). Input shaft lubricated and odometer set back to zero.
Front Tin - OE - Factory-style formed opening added for the tach. The paint is nice condition factory original Video
Back Tin - OE - Tach hole added using a CNC router based on a pattern made from a factory tach tin. The opening is positioned slightly lower than the stock 5k tach location to optimize the alignment of the 8k tach with the lens numbers. The paint is nice condition factory original Video
Lens -OE - Dummy tach markings removed, and die-cut decals applied for the 8k tach. The lens is nice, and it has very little in the way of swirl marks or scratches. Video
Bezel - Reproduction 67-68 style from Auto Metal Direct. NOTE: CAN BE SWAPPED OUT FOR A 69-72 STYLE IF YOU WANT
Printed Circuit - Brand new reproduction
Bulbs - Tested good
$450 + shipping
Zelle, CashApp or money order only.
Send me a PM or email me at dummyfillernecks@gmail.com if you have any questions.
pjmoreland is offline   Reply With Quote
Old 08-30-2024, 12:02 PM   #2
pjmoreland
pjmoreland's Avatar
Re: 8k Tach Cluster
Photos of the back
Old 08-30-2024, 12:03 PM   #3
pjmoreland
pjmoreland's Avatar
Re: 8k Tach Cluster
Light testing
Old 08-30-2024, 12:04 PM   #4
pjmoreland
pjmoreland's Avatar
Re: 8k Tach Cluster
Temperature Gauge
Old 08-30-2024, 12:05 PM   #5
pjmoreland
pjmoreland's Avatar
Re: 8k Tach Cluster
Battery Gauge
Old 08-30-2024, 12:06 PM   #6
pjmoreland
pjmoreland's Avatar
Re: 8k Tach Cluster
Oil Pressure and Fuel Gauges
Old 08-30-2024, 12:07 PM   #7
pjmoreland
pjmoreland's Avatar
Re: 8k Tach Cluster
Speedometer
Old 09-01-2024, 12:07 PM   #8
Michael D
Junior Member
Re: 8k Tach Cluster
Hey there, if this is still available and we can swap in the 67-68 for a 69-72 cluster frame I'd like to take this off your hand.
Mike
Michael D is offline   Reply With Quote
Old 09-01-2024, 12:08 PM   #9
Michael D
Junior Member
Re: 8k Tach Cluster
check your PMs
Old 09-01-2024, 12:29 PM   #10
pjmoreland
pjmoreland's Avatar
Re: 8k Tach Cluster
Mike
Good morning. It is still available, and I'm happy to swap out the bezel to a new 69-72 style.
Old 09-01-2024, 12:42 PM   #11
Michael D
Junior Member
Re: 8k Tach Cluster
Ditto
Old 09-03-2024, 12:06 PM   #12
pjmoreland
pjmoreland's Avatar
Re: 8k Tach Cluster
I swapped the bezel to a 69-72 style. I will ship it out today. I'll send you a tracking number in a little bit.
Old 09-03-2024, 02:31 PM   #13
Michael D
Junior Member
Re: 8k Tach Cluster
Pretty.
Thank you sir.
