Old 08-30-2024, 08:20 PM   #1
Don D
Junior Member
GM Automatic Tilt Steering Column Shortened 2”
GM Automatic Tilt Steering Column Shortened 2”. It has been shortened to give more room between the steering wheel & the seat, moves the steering 2” closer to the dash. So if you are a big guy it gives you some more room. The column was stripped down & checked for worn or broken parts & replaced if needed. Column was painted back black & the reassembled using the following new parts. Turn signal switch & wiring harness with the correct curved wire connector, neutral safety switch, lower bearing, lower bearing retainer, upper & lower rubber seals, inside tube seal, shift indicator pointer, shift indicator lense, hazard light knob, shift lever, turn signal lever, tilt lever & cancel cam / horn contact. It is ready to bolt in & go.
$675.00 Plus Shipping / Shipping to the US only.
Don D is offline   Reply With Quote
Old 08-30-2024, 08:23 PM   #2
Don D
Junior Member
more pics
Old 09-01-2024, 01:14 AM   #3
YBNORML
YBNORML's Avatar
Re: GM Automatic Tilt Steering Column Shortened 2”
Hey Don, im very interested. Can you give me a day to organize shipping? I just have to confirm things.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 09-01-2024, 02:02 PM   #4
YBNORML
YBNORML's Avatar
I’ll take it.
Pm sent.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 09-07-2024, 02:06 PM   #5
MeanGreen72C10
MeanGreen72C10's Avatar
I'll take this if the deal with YBNORML falls through.
MeanGreen72C10 is offline   Reply With Quote
Old 09-10-2024, 07:12 PM   #6
Don D
Junior Member
Sold to YBNORML Thanks
