Old 09-01-2024, 10:46 AM   #1
Detour
Junior Member
What is this distributor?
I’m swapping out the manifold so I pulled the distributor yesterday and I’m rather confused. Truck is a 1967 K20 with a 1964 Impala motor. I was expecting an old points ignition, but realized I have something else. The coil is the round canister coil instead of the integrated on HEI. The cap has no wire connectors and there’s only one wire coming from the bottom of the distributor. Inside the distributor, there is no circuit board like an HEI And no points clean.
Detour is offline   Reply With Quote
Old 09-01-2024, 11:07 AM   #2
Orange71shorty
Re: What is this distributor?
Looks like a stock points distributor to me. HEI was later and never came on 67-72 trucks
Orange71shorty is offline   Reply With Quote
Old 09-01-2024, 11:36 AM   #3
Getter-Done
Getter-Done's Avatar
That just a regular points type distributor.
That set of points has the condenser installed directly to the points body.
The early bird gets the worm,
84 Chevy K-20
Old 09-01-2024, 11:48 AM   #4
Detour
Junior Member
Thanks. I'll take a closer look at it. I thought it was points distributor, but didn't see the contacts to inspect for cleaning. It's got some rust under the weights so I'll just pull it apart and inspect. Thanks for the help.
There was a condenser on the side of the coil. Does that mean I should eliminate the second exterior condenser?
Old 09-01-2024, 11:58 AM   #5
truckster
truckster's Avatar
If you rotate the distributor shaft you'll see the points open and close.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-01-2024, 12:06 PM   #6
yuccales
yuccales's Avatar
The one on the coil is to do away with the "audio tach" feature on your AM radio. Just kidding, it's the ignition noise suppressor.
yuccales is offline   Reply With Quote
Old 09-01-2024, 12:55 PM   #7
Detour
Junior Member
Disassembled the distributor to clean things up and inspect. Definitely see the points now and they need to be replaced. They are all jagged like they had been stuck together at some point in the past and didn’t separate cleanly.
Haha, Yuccales I do know exactly what you mean on the AM stations.
Thanks again guys
Old 09-01-2024, 01:45 PM   #8
Lokin4AReason
Lokin4AReason's Avatar
that is points alright
they have a few kit(s) available at were you can replace it w an upgrade in eliminating the points . with also keeping a stock look to it
https://www.summitracing.com/search/...ll-block-gen-i
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 09-01-2024, 02:41 PM   #9
geezer#99
geezer#99's Avatar
They’re called a uni-set.
Two downfalls to them.
Hard to set gap due to access and you use an Allen wrench to adjust them.
Also need a dwell meter.
Old 09-01-2024, 03:40 PM   #10
Getter-Done
I am very familiar with them.
A Mechanic that rented the shop in front of my Momma and Daddy's house would pull those out as soon as he seen them.
Then he would replace them with what (He Called) the regular set.
I still Remember his dislike for them.
I still have the dwell meter box he used.
84 Chevy K-20
Old 09-01-2024, 04:31 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Reading about points-type distributors reminded me of hearing, decades ago, that you could set points with a matchbook cover. I never actually did that, but.... do they still even make matchbooks? Used to see 'em everywhere, often given away as free advertising. I don't recall seeing one for a whole lotta years. I do remember them switching from front-strike to rear-strike. One of the early steps to protect us from ourselves.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 09-01-2024, 04:40 PM   #12
Getter-Done
Yeah they still have those matchbooks.
Link: https://www.amazon.com/30-Strike-Mat...s%2C814&sr=8-1
I have seen people years ago take a penny to clean the contacts.
So that they could make it to the nearest station to get them changed out.
84 Chevy K-20
Old 09-01-2024, 04:43 PM   #13
RustyPile
RustyPile's Avatar
GM uses a unique "uniset", the points and condenser are connected together as a unit.. The proper method is to use a dwell meter to set the points with the engine running.. A dwell meter is almost impossible to find today, but it's possible to use a feeler gauge.. Before you install the distributor, rotate the shaft to set points rubbing block on one of the peaks of the shaft.. Use an allen wrench and feeler gauge, set the points gap to .018"..
If you are able to locate a dwell meter, set the points to 32 degrees.
RustyPile is offline   Reply With Quote
Old 09-01-2024, 05:06 PM   #14
truckster
truckster's Avatar
I still have a dwell meter. I haven't used it for many years, but you never know...
Old 09-01-2024, 07:39 PM   #15
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I still have a dwell meter and the flex shaft Allen for adjusting the points.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 09-01-2024, 08:47 PM   #16
Getter-Done
I remember those flex shaft allen .
Do you have one of those locking screw holders?
The one that use used to hold the screw,
to keep from dropping the screw to the bottom of the distributor.
84 Chevy K-20
Old 09-01-2024, 09:31 PM   #17
Steeveedee
Who Changed This?
Steeveedee's Avatar
I have that flex driver and two of those locking screwdrivers, one short and one long. Both with magnets. I also have a clutch head driver set for those '50 Chevies I had and worked on. Still have the dwell/tach I bought in about '76, too.
~Steven
Simi Valley, CA
Old 09-02-2024, 12:03 AM   #18
Accelo
Accelo's Avatar
Core Distributor 8-283 ID-1111150 Fits 1967 CHEVROLET 1500
Accelo is offline   Reply With Quote
Old 09-02-2024, 02:09 AM   #19
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Can’t Remember last time I saw Points in a Distributor.
Now that I have an LS can’t remember last time I saw a Distributor
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 09-02-2024, 10:55 AM   #20
Sheepdip
Sheepdip's Avatar
Urban Hotrodders Rumor was that a match book cover was perfect for setting point gap, never did it or seen it done, but knew guys who claimed it worked, anything that works when in a bind is probably how it first got used.
Sheepdip is online now   Reply With Quote
Old 09-02-2024, 01:27 PM   #21
1970cstblazer
1970cstblazer's Avatar
Exclamation Re: What is this distributor?
After a MSD electronic distributor module failure while in storage for a few months, I went back to traditional points in my 1972 402 Cheyenne, and retained them in my 1970 Blazer. Key is to only use NOS USA made Delco points with the separate condenser unit, points gap to .019", dwell at 30 degrees(recommended range is 28-32), and to ensure the distributor points cam is lubed with the correct lubricant. I also use NOS green stripe AC spark plugs in all of my vintage GM vehicles. Both the truck and Blazer start instantly in any weather, and run excellent and consistently. These will last several years with my below 1000 mile a year usage of either vehicle.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
1970cstblazer is online now   Reply With Quote
Old 09-02-2024, 02:13 PM   #22
truckster
truckster's Avatar
I had to do it once in an emergency. It wasn't perfect, but it would get you back on the road.
Old 09-02-2024, 06:19 PM   #23
RichardJ
I have a box of match books. .017" for the cover and just under .015" for the match sticks. .019" is for NEW polished contact points. Used points, even when filed relatively smooth, have to be set with a thinner gauge to achieve the desired dwell.
Match cover thicknesses do vary, but more accurate than eyeballing it. In the image, a 016" gauge can produce a really wide gap if you don't do some cleaning.
I have done it myself. With a screwdriver, a matchbook found on the side if the road and a street light to see by.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 09-02-2024, 09:03 PM   #24
Rust_never_sleeps
Rust_never_sleeps's Avatar
If the dizzy has a clamp for the "detached condenser" style can, they are a lot easier to tune. I was too dumb to answer that question correctly, so ended up doing it the hard way. Blue Streak points have been working fine for me.
If anything else is worn on the distributor, it's prolly worth upgrading to one of the Pertronix igniters/distributors/HEI's depending on how deep you want to go
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
