08-04-2024, 09:18 PM | #1 |
Remote Batt. Disconnect
Anybody tried one of these yet?
Can't seem to find any posts but that doesn't mean there aren't any out here someplace. I would like to see them be built stronger like in the USA for example, and at first the thing was giving me trouble and I was about to remove it, but that's when I discovered I hadn't fully tightened the screws down yet. So far so good after a few months. |
08-04-2024, 09:36 PM | #2 |
Re: Remote Batt. Disconnect
That looks like a lot of wires, and a lot of stuff connected to other stuff. Many connections, many bolts. I'm curious. What does all that stuff accomplish?
08-04-2024, 10:57 PM | #3 |
Maybe something like this. Zoom in for a better look.
08-04-2024, 11:17 PM | #4 | |
Oh it gets even better! I don't remember what half that stuff does after 30 years of ownership and I suppose I could have come up with a fuse block at some point, but everything works great so if it ain't broke I ain't fixin' it! |
08-04-2024, 11:23 PM | #5 |
I Like it.
08-04-2024, 11:34 PM | #6 |
All I can think of to say is Gee Willikers.
08-05-2024, 05:10 AM | #7 |
08-05-2024, 06:43 AM | #8 |
Remote battery disconnect issue while having a local nightmare and unwilling to fix it. Ok, you're fine.
08-05-2024, 07:20 AM | #9 |
There's nothing to fix, everything on that truck works just fine, and if the dang remote disconnect unit quits, all I have to do is remove the negative ground cable clamp from that unit and plug it back directly onto the negative battery post.
A simple one or two minute job tops. ...more like less than 30 seconds, I have the tool boxes bolted in right there under the hood beside it. Last edited by BRL; 08-05-2024 at 07:38 AM. |
08-05-2024, 09:16 AM | #10 |
I have one right now to install in my truck ,, it has a clicker to go on my key chain and I want it because I unhook the battery at home or out some where almost each time I drive the truck when I am aways in distance ,, I figure it is another thing to have along with my locking doors to make it a bit harder to theft . I am going to add longer wires and mount it on the side wall next to the battery .. I like it ..
When you learn a thing a day you store up smart. |
08-05-2024, 09:58 AM | #11 |
Yea it just amazes me that the thing has held up as well as it has already, I'm used to believing that a car battery disconnect switch should be seriously built like a massive breaker switch in a power substation or something, but only time will tell if it will hold up or not.
I do like the concept though. |
08-09-2024, 10:09 PM | #12 |
Getter-Done you're my new bestest buddy on this forum, you seem to understand me
As for the rest of you, Amazon just delivered a bus bar distribution block and I'll try to clean up this mess even though I'm immune to peer pressure. |
08-09-2024, 11:14 PM | #13 |
That bus bar distribution block sure accommodates lots of wires, and a lot of stuff connected to other stuff. Many connections, many screws. Gee Willikers!
08-10-2024, 12:05 AM | #14 |
yea, well, I need to supply power to the shower hot water heater and the SETI radar satellite dish.
08-16-2024, 12:29 AM | #15 |
OK I cleaned up the mess somewhat.
Now it looks so good I'm thinking of removing the hood and driving around town to show it off. The reason I bolted in toolboxes under the hood is because I have stereo amplifiers under both bucket seats, that's where all those wires were headed. You install a powerful stereo system in a tiny truck cab and it'll blow your head off! I was young once. |
Today, 12:25 AM | #16 | |
It all works. So I was thinking of putting a kill switch under the dash and decided that drilling a hole in that plate shown would work, so I removed the 4 bolts that attaches it. Nope, decided on a different location so I went to reinstall the plate... Somehow the two screw holes towards the driver's seat became misaligned and its a darn good thing the bolts come to a point because that task wore me out! Had to take a nap afterwards, I think I had an easier time bolting in the motor. |
Today, 12:33 AM | #17 |
Today, 12:38 AM | #18 |
I had the same experience with that plate, the 4 bolt holes did not align worth a damn. I could not believe I removed the plate with such ease, and it was hell to put back on. I had it off before and don't remember it being difficult to put back on. I would imagine there is some clever trick to it we don't know.
Today, 01:49 AM | #19 |
Yea I couldn't line up those holes, even using a Phillips screwdriver shank as a crowbar in an attempt to line up the holes, nothing budged.
That plate assy. did have a cluch pedal at one time but I removed it and trashed it (oops!) if that makes it any difference, but the whole experience was just ridiculous. At least I know it wasn't just my experience alone, thanks for that. That under dash creeper looks a lot like a stretcher, I could have used a stretcher when I was done. |
Today, 02:37 AM | #20 |
A battery disconnect is usually thought of as completely disconnecting the battery from the vehicle. Disconnecting just the low current stuff can be done with a relay and a bus much like the one posted. Squares had a nice one if there's a scrapyard around.
