Old 09-04-2024, 10:01 AM   #1
72c20customcamper
72c20customcamper's Avatar
Manual drum brake issue
I redid all the brakes on my 68 consisting of new shoes, cylinders and had the drums resurfaced last fall . The brakes pulled slightly to the right so I adjusted the shoes to full lock and then backed off till there was drag on all four. I took it out today and was on my gravel driveway . It’s a long drive so I got it up to 20-25 mph and slammed the brakes. Both passenger brakes locked up and skidded on the gravel . Drivers side didn’t even disrupt the gravel . I drove around around applying the brakes and the left front/rear got warm so I know they are active. But not working properly I’m going to pull a drum and look at the shoes anything I should look for ?
It’s puzzling that one side isn’t working but the other side works great .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 09-04-2024, 11:57 AM   #2
72c20customcamper
Re: Manual drum brake issue
I’m a dumb ass don’t rush doing brakes . Rear the push pin from the wheel cylinder was not engaged . Not sure what the issue was on the fronts I scuffed the rotor and shoes didn’t see any problem but I can lock up all four on blacktop now .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-04-2024, 01:55 PM   #3
Rust_never_sleeps
Rust_never_sleeps's Avatar
It's been a long time since I've seen new brake shoes, but those don't look new ;-)
Good you got is sorted out
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old 09-04-2024, 03:24 PM   #4
72c20customcamper
I put them on last year been sitting in my barn with about 2 miles on them. The rust is what came off the drums from sitting and may be the reason the front wasn’t working well till after I cleaned the shoes and drum . Cobwebs in the first picture tells the tale
Edited the first post to reflect the time period
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-04-2024, 03:37 PM   #5
72c20customcamper
I did the brakes last August .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-04-2024, 08:55 PM   #6
custom10nut
custom10nut's Avatar
Though it didn’t involve my 70, (original 4 wheel drums), I went through the same struggle on my Dually. I had to replace one of the cylinders on the rear, and had that hub on and of no less than five times before I finally figured out that I forgot one of the small levers for the auto adjuster.
The conundrum was that the hubs are so bulky that I didn’t want to take the other side off to use it as a reference. In the end, that would have been a WHOLE lot easier
custom10nut is offline   Reply With Quote
Old 09-05-2024, 12:07 AM   #7
Sheepdip
Sheepdip's Avatar
I can't count on my fingers and toes how many brake jobs I've done over the years, but I always take a picture before I start....my memory is short but a picture is the ticket to success.
Before todays tech I had one of them polaroid instant picture cameras
Sheepdip is offline   Reply With Quote
Old 09-05-2024, 12:16 AM   #8
Getter-Done
Getter-Done's Avatar
Originally Posted by Sheepdip View Post
I can't count on my fingers and toes how many brake jobs I've done over the years, but I always take a picture before I start....my memory is short, but a picture is the ticket to success.
Before today's tech I had one of them polaroid instant picture cameras
That's the picture that you needed to (Shake) fan it till dry.
84 Chevy K-20
Old 09-05-2024, 12:19 AM   #9
Sheepdip
Sheepdip's Avatar
Yep that be the one!
Old 09-05-2024, 01:57 PM   #10
72c20customcamper
This is all on me . Not doing a quick check of my own work .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-05-2024, 02:05 PM   #11
Rust_never_sleeps
I find at work that the answer will become painfully obvious just AFTER I've hit enter and admitted my incompetence by asking a broad spectrum of co-workers
Old 09-05-2024, 04:40 PM   #12
Rust_never_sleeps
Yeah, I just didn't look at the top pic and the shoe material just looked really thin in the bottom one for some reason
Old 09-05-2024, 04:43 PM   #13
70STOVEBOLT
70STOVEBOLT's Avatar
We all have dumbass attacks sometimes.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 09-06-2024, 10:59 AM   #14
67C10Step
67C10Step's Avatar
Been in that exact place before, only on the fronts. It was my teenage years and that first attempt at a stop was really interesting with only one front brake grabbing.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 09-06-2024, 11:55 AM   #15
jabborabbo
jabborabbo's Avatar
I’ve had brain flatulence - one time I changed the disc brake pads on a car (something I’ve done a lot) and as always (fortunately) I took the car for a test drive afterward - hit the brakes and heard a horrible screeching sound… turned out I had put the pads in backwards…metal against metal…Jeez….
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense
jabborabbo is offline   Reply With Quote
Old 09-06-2024, 12:08 PM   #16
70STOVEBOLT
Someone should start a "repair mistakes & blunders" thread. I always like reading the stories in the Rock Auto newsletters.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 09-06-2024, 12:28 PM   #17
jabborabbo
jabborabbo's Avatar
