Old 08-19-2024, 07:49 PM   #251
TX3100Guy
TX3100Guy's Avatar
Re: Eliminate draft tube options
More photos of my engine in process. Should be started and test run tomorrow.
1953 Chevy 3100 - 5 window 1/2 ton pickup
My 1953 Chevy Work-In-Process Photo Gallery
"I don't have a carbon footprint, I drive everywhere."
TX3100Guy is offline   Reply With Quote
Old 08-21-2024, 10:50 AM   #252
dsraven
looking good. soon it will be in your shop.
possibly consider a support clamp on the oil pressure sender because vibration causes cracks in the fittings. the longer and heavier the parts are then the ore chance of having an issue. I have seen some crack at the exit from the block and you don't want that. easier to whip up a clamp before it goes into the truck.
you're gonna have fun driving soon. kepp posting up pics as you go
Old 08-26-2024, 05:51 PM   #253
TX3100Guy
TX3100Guy's Avatar
Link to video of first engine run.
https://youtube.com/shorts/235dRdHrL...6EZUd-Madz1saB
My intake, his exhaust, alternator, etc.
Old 08-26-2024, 07:02 PM   #254
geezer#99
geezer#99's Avatar
Did you break in the cam? Ran it at 1500-2000 rpm for 20 minutes.
In the video the rpm sounds low.
Old 08-26-2024, 07:37 PM   #255
TX3100Guy
TX3100Guy's Avatar
Yeah, the builder has run it multiple times including a run to burn in the cam. He’s going to run it again tomorrow for another high rpm run prior to shipping.
Old 08-26-2024, 09:10 PM   #256
dsraven
Nice. Gotta be getting antsy now. Gonna be soo-eet!
Old 08-27-2024, 08:45 AM   #257
my56chevytruck
my56chevytruck's Avatar
Originally Posted by tx3100guy View Post
link to video of first engine run.
https://youtube.com/shorts/235drdhrl...6ezud-madz1sab
my intake, his exhaust, alternator, etc.
your engine sounds great, congrats
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 08-28-2024, 03:17 PM   #258
TX3100Guy
TX3100Guy's Avatar
The pallet with the engine is now in the hands of FedEx Freight. I should have the engine on Tuesday, since Monday is Labor Day. More pics to come once its in my hot little hands.
Old 08-29-2024, 11:19 AM   #259
dsraven
now be a good boy and sit tight for the long weekend. don't be polishing wrenches or dreaming about installing and starting that engine, listening to it rumble......
haha
good you have a confirmation of shipment. you'll be test driving soon.
Old 08-29-2024, 11:32 AM   #260
TX3100Guy
TX3100Guy's Avatar
haha
A buddy of mine accused me of sitting in the truck playing the video loud and pretending to drive the truck. LOL
Old 08-29-2024, 11:35 AM   #261
dsraven
I guess you could spend some time cleaning the windows then, prolly spit all over them from you making engine sounds. haha
Old 09-04-2024, 10:14 PM   #262
TX3100Guy
TX3100Guy's Avatar
After months of waiting, my rebuilt 1959 261 straight six has finally arrived. Now to get to work installing it.
Old 09-04-2024, 10:23 PM   #263
dsraven
That's awesome! You must be excited to get after it.
Old 09-06-2024, 02:05 PM   #264
TX3100Guy
TX3100Guy's Avatar
Snug as a bug in a rug.
Old 09-07-2024, 07:29 PM   #265
dsraven
sooo-eeet!
now the accy and soon, BOOM, driving!
Old 09-07-2024, 07:44 PM   #266
geezer#99
geezer#99's Avatar
Considering the front mount, is there a need for an engine tie down strap?
Old 09-07-2024, 07:47 PM   #267
TX3100Guy
TX3100Guy's Avatar
You tell me. How and where?
Old 09-07-2024, 08:01 PM   #268
TX3100Guy
TX3100Guy's Avatar
It also has two mounts on either side of the bell housing.
Old 09-07-2024, 09:36 PM   #269
geezer#99
geezer#99's Avatar
What are you using for a throttle hook up?
I’ve seen a steel cable looped over an exhaust manifold close to the head and tied onto the frame.
Old 09-08-2024, 06:45 PM   #270
TX3100Guy
TX3100Guy's Avatar
I have a knock-0ff Lokar pedal that mounts through the firewall and the stainless steel sheathed cable goes up the sealed car enclosure for my McCulloch supercharger (from a 1957 Studebaker Golden Hawk) and attaches to the throttle mechanism.
Old 09-09-2024, 11:59 AM   #271
geezer#99
geezer#99's Avatar
Your lokar cable is better than a mechanical linkage.
If a mount breaks at least your engine won’t go full throttle.
A steel cable looped from the front of the engine (drivers side ) down to the frame is just a precautionary device. Just in case a mount breaks and the motor twists up to the passenger side.
Old 09-09-2024, 12:43 PM   #272
TX3100Guy
TX3100Guy's Avatar
Have any pictures that show how it’s attached to the engine and frame?
Old 09-09-2024, 01:32 PM   #273
geezer#99
geezer#99's Avatar
Lots of info here plus some pics.
https://garage.grumpysperformance.co...r-mounts.2617/
Old 09-10-2024, 07:10 PM   #274
mr48chev
mr48chev's Avatar
That looks great in there.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 09-10-2024, 09:38 PM   #275
dsraven
if you have a place nearby that makes cables with pressed on connections you could have a cable made for the purpose of engine torque restriction, you know, to save the hassle of a motor mount giving out and causing damage. they could press on a connection with a bolt hole the size you need and the cable length you need. ensure to leave a little slack so the engine can move a little otherwise you will hear the harmonics of the engine through the solid link to the frame when the engine pulls even a little.personally I think cable looks better than chain, just me though.
