adjust side to side gap on hood
Before I do something stupid, which would a nice change, I thought I would ask the group first. I put the hood on my '67 with it all the way forward in the slots. When I checked to see how the fender to hood gap was one side was tight and the other had about a 3/8" gap. The gap looks even all the way down so the hood is not crooked. I loosened the hood bolt and pushed the hinge over to see if that would help but it didn't. All the parts are OEM so I'm not dealing with an after market issue.
My question is how best can I address this issue? From what I can find out on the forum and internet you just bend the hinge to fender part of the hinge to force it over.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
![]() Join Date: Oct 2020
Re: adjust side to side gap on hood
Fender shims?
I thought about fender shims but have never seen them used for the hood hinge. Just wanted to see what everyone did to address this issue. Utube was no help and I haven't been able to find any help on the forum. The ones I have found only address the rear of the hood or front alignment
![]() Join Date: Nov 2013
Mine was off about 1/16" when I put it on, I thought about slotting the hinges a little wider but my body guy came buy, looked at it, opened it up and just violently pushed it over toward the wide side a few times.
It lined it up perfectly.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
Lmao, thanks A1971 Blazer. I thought about doing something like that but usually get in trouble when I do
I'll give it try and see if it works for me.
#6 | |
![]() Join Date: Jul 2003
I've done this several times. The only way to correct side to side gaps.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
