Old Today, 09:01 PM   #1
kna4977
Heater Fan doesn't blow on low
A/C cab fan motor doesn't blow on low at all. Will blow on medium sometimes and will blow on high always. Where should I start?
kna4977 is online now   Reply With Quote
Old Today, 09:15 PM   #2
Richard
Re: Heater Fan doesn't blow on low
The resistor in the ducting, fan switch and connector on fan switch.
Richard
Old Today, 09:37 PM   #3
kna4977
Where is the resistor in the ducting? Fan works just not on all speeds. Connector looks good.
Old Today, 10:11 PM   #4
dmjlambert
dmjlambert's Avatar
In the heater core box attached to the firewall inside the cab. Here the box is shown removed and upside down while I was working on it. There is a little door through which you can peek at the resistor board, but to get real access you need to take more apart.
Old Today, 10:56 PM   #5
kna4977
Is that part serviceable? Is there a modification/work around to eliminate the resistor altogether?
Old Today, 10:57 PM   #6
Richard
What dmjlambert said. In his provided pic you can see two screws, They hold the "S" duct adapter in place. Remove those screws and the ones securing the "S" duct to have access. Not real difficult. The resistor is available at many vendors, here is one of my go to places https://classicparts.com/1964-72-a-c...-w-factory-air
Richard
Old Today, 11:07 PM   #7
kna4977
I see the two screws is there a schematic I can't quite picture where its at and how it's oriented with that single pic.
Old Today, 11:14 PM   #8
Richard
Look at the heat outlet on the floor above the transmission hump. Left to right- Heat outlet, "S" duct then the fitting screwed the the box shown. As mentioned, pic shows box upside down.
Richard
