Old 09-07-2024, 10:58 PM   #1
Cmace22
Help Identifying SWB frame
I purchased this frame for a 72 c10 short bed build I am doing. It was advertised as a 72 frame. Can someone please help me confirm this before I spend time on getting this thing ready. It has front disk and drum rear. Its hard for me to tell the difference between the years as they as look so similar. Thank You!
Cmace22 is offline   Reply With Quote
Old 09-07-2024, 11:26 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Help Identifying SWB frame
'72 would have disc brakes. I believe that the serial number is stamped on the frame, but it may not include the year information. If you can't find welds or fish plates, it's probably the real deal.
~Steven
Simi Valley, CA
Old 09-07-2024, 11:38 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
The top of the drivers side front frame rail near the steering box should have a partial vin stamped in it. It will have the year, plant code and sequence number of the vin. As an example my 72 K20 has 72J160173 72 for the year, j for Janesville, and 160173 as the build sequence number; 1 is a check digit. Mine was the 60,173 truck to roll out of Janesville in the 72 model year.
If you’ve got front disks it’s most likely a 71-72 frame.
Tyler
Old 09-07-2024, 11:56 PM   #4
RustyPile
RustyPile's Avatar
It's possible they could have been changed, but t clam shell engine mounts also say it's '72.. As others have said, the numbers on the frame will tell the story...
RustyPile is offline   Reply With Quote
Old 09-08-2024, 12:11 AM   #5
Cmace22
Here are the number near the power steering box. I don't see anything that resembles a year. 1B623912 it looks like.
Old 09-08-2024, 01:29 AM   #6
dagnabbitt
dagnabbitt's Avatar
If betting were allowed I would put a dollar on that being a 1971 frame, built in Baltimore. Which if google is correct, is a city that is somewhat near you.
https://67-72chevytrucks.com/vboard/...28&postcount=7
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
dagnabbitt is online now   Reply With Quote
Old 09-08-2024, 03:44 AM   #7
Greasey Harley
Greasey Harley's Avatar
I don't know what the year is, but If you're piecing a frame to a cab, I recommend getting documentation from the DMV or State Police.
Every place is different, but up here in Kootenai County, ID, Vehicles being transferred from out of state are subject to a "VIN inspection". They WILL check the vin on the frame and if It doesn't match the title, they are likely to IMPOUND the vehicle (at the owner's expense) until it's figured out.
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 09-08-2024, 09:48 AM   #8
57taskforce
All about them K’s
Yep that’s exactly what he’s got. 71 Baltimore. 23,912 truck built in the 71 model year.
Tyler
Old 09-08-2024, 12:23 PM   #9
Cmace22
Awesome fellas!! Thank you all for helping me out.
Old 09-08-2024, 04:44 PM   #10
too much stuff
Roadtrip!
too much stuff's Avatar
The clam shells on this one are 73 and up.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 09-08-2024, 10:18 PM   #11
mr48chev
mr48chev's Avatar
The disk brakes and coil rear springs say 71/72. Motor mounts "should be" 73 or later but who knows what goes on during an engine swap.
I'll agree that even if you have a title to the cab it is a bit risky these days to not have it inspected because of the frame change and have that documented by the state. You need a bill of sale that states that you just bought the frame as parts or the receipt from the wrecking yard if it came out of a wrecking yard.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
