Old 09-06-2024, 02:39 PM   #1
Peanut74
adjust side to side gap on hood
Before I do something stupid, which would a nice change, I thought I would ask the group first. I put the hood on my '67 with it all the way forward in the slots. When I checked to see how the fender to hood gap was one side was tight and the other had about a 3/8" gap. The gap looks even all the way down so the hood is not crooked. I loosened the hood bolt and pushed the hinge over to see if that would help but it didn't. All the parts are OEM so I'm not dealing with an after market issue.
My question is how best can I address this issue? From what I can find out on the forum and internet you just bend the hinge to fender part of the hinge to force it over.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 09-06-2024, 03:18 PM   #2
68 C10 Driver
Re: adjust side to side gap on hood
Fender shims?
68 C10 Driver is offline   Reply With Quote
Old 09-07-2024, 09:02 AM   #3
Peanut74
I thought about fender shims but have never seen them used for the hood hinge. Just wanted to see what everyone did to address this issue. Utube was no help and I haven't been able to find any help on the forum. The ones I have found only address the rear of the hood or front alignment
Old 09-07-2024, 10:16 AM   #4
A1971Blazer
A1971Blazer's Avatar
Mine was off about 1/16" when I put it on, I thought about slotting the hinges a little wider but my body guy came buy, looked at it, opened it up and just violently pushed it over toward the wide side a few times.
It lined it up perfectly.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 09-08-2024, 10:33 AM   #5
Peanut74
Lmao, thanks A1971 Blazer. I thought about doing something like that but usually get in trouble when I do
I'll give it try and see if it works for me.
Old 09-08-2024, 05:34 PM   #6
RustyPile
RustyPile's Avatar
That's exactly the way they did it on the assembly lines.. 2X4s, big guys, push a little, pull a little.. Ask Keith Seymore...
RustyPile is online now   Reply With Quote
Old 09-08-2024, 08:00 PM   #7
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: adjust side to side gap on hood
I've done this several times. The only way to correct side to side gaps.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 09-09-2024, 01:30 AM   #8
Greasey Harley
Greasey Harley's Avatar
I absolutely learned something new here, good stuff!
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 09-09-2024, 10:25 AM   #9
pjmoreland
pjmoreland's Avatar
The hood latch striker that attaches to the underside of the hood is adjustable. You can loosen its four mounting bolts and scoot it left or right. Even if you massage the hinges so that the hood wants to be centered, an off-center striker will push the hood out of position as it engages the latch.
pjmoreland is online now   Reply With Quote
Old 09-09-2024, 01:32 PM   #10
PbFut
Side to side I did as others....Just get a little rough with her. She'll straighten out. I got pretty close with this method. It was ok but not perfect. Then I placed the rubber bumpers in the hood channel. That really helped fine tune the fit. And yes, allow the hood pin to float some the tighten down. Once all done, the bumpers not only finished centering but also gave a nice pop when I released the hood. Adjusting the hood pin really gave a nice feel to opening the hood. I no longer needed to grip exercise daily to open my hood.
PbFut is offline   Reply With Quote
