Old 09-10-2024, 11:05 PM   #1
BDC90
Cold start issue
Old Q-jet 1971. Runs good idles good starts when warm right away. Cannot get it to start cold without a tiny sprits of fast start. Carb rebuilt , settings double checked. There is some primary shaft play but it returns to 650 rpm when I let of the throttle. Is rebushing the shafts really gonna fix this? It doesn't seem like that little bit a vacuum leak would have that much negative affect with choke on during cold start. Anybody got any ideas? Accelerator pumps down both holes (4MV) , no hesitation when the throttle is blipped.
BDC90 is offline   Reply With Quote
Old 09-10-2024, 11:56 PM   #2
geezer#99
geezer#99's Avatar
Re: Cold start issue
When you first pump it to give it some fuel and set the high idle, is the choke closing all the way?
Old 09-11-2024, 12:34 AM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
That was my first thought.
Does the OP have the original cold start system, thermostatic air cleaner, riser, divorce choke and such?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-11-2024, 07:49 AM   #4
RustyPile
RustyPile's Avatar
If the choke is closing all the way, my first thought is metering well plugs are leaking..
RustyPile is offline   Reply With Quote
Old 09-11-2024, 09:11 AM   #5
BDC90
All original so I'll double check the choke blade. The well plugs are the later style so pretty sure they don't leak.
Old 09-13-2024, 10:22 AM   #6
BDC90
Re-adjusted choke arm, it may have been a little off but blade closes completely now. Truck started. Later that day (7 hours) truck started. Today truck no start. It's gotta be combo of 54 year old thermosatic coil and worn primary throttle shafts. It takes a long time before the coil will let the idle speed drop. The truck runs great after it starts and starts right up when warm.
Old 09-13-2024, 11:55 AM   #7
geezer#99
geezer#99's Avatar
Describe your cold start procedure.
Old 09-13-2024, 11:57 AM   #8
BDC90
Truck in neutral gas pedal to floor, let pedal up and turn key.
Old 09-13-2024, 12:18 PM   #9
geezer#99
geezer#99's Avatar
Pump it twice.
Once might not deliver enough fuel.
Another thing that helps is more timing.
What’s your initial timing set at?
Old 09-13-2024, 12:51 PM   #10
Wrenchbender Ret
Pump the gas pedal as you crank it when cold. The accelerator pump pulls off the bottom of the fuel bowl. As soon as the gas gets to the bowl the accel. pump will prime it & it will start. When engine is warm after setting a while hold the gas pedal down while cranking to clear out any flooding from percolation.
George
Wrenchbender Ret is offline   Reply With Quote
Old 09-14-2024, 12:53 PM   #11
BDC90
Timing is set at specs from the manual +4 I think? The double pump worked today so I'll keep doing that until it doesn't. Waiting for the antique plates so We can start driving it.
Old 09-16-2024, 04:18 PM   #12
71CHEVYSHORTBED402
When my truck's cold, I nearly always have to start it by procedure, twice. Perhaps I should add, with the key on one engine turn-ish. I'm no expert, it only takes a second. Rebuilt carb., almost fresh everything and tune.
Tony
Old 09-16-2024, 04:32 PM   #13
BDC90
Well that would have been a handy sticker to have. This truck has the instructions for the PTO winch in that spot. Of course We do not have an owners manual either. Yet.
Old 09-16-2024, 05:28 PM   #14
Rust_never_sleeps
Rust_never_sleeps's Avatar
re-bushing the q-jet is not a big job, and it does make idle/choke/mix more predictable. Hard to know how much difference
I wish I had a sight glass in mine, cuz knowing if the bowl is full when working alone makes for less guesswork about pumping the pedal
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old 09-16-2024, 08:19 PM   #15
71CHEVYSHORTBED402
I have one, but can't bring myself to install it on a perfectly good visor. I don't think my 71 had one. Didn't have one when I got it in 89 anyway. Ha ha, I just looked at the date on those instructions, my May 1971 truck didn't have that decal.
The instructions say start a warm engine with the pedal halfway down. I've never had to do that (402, 4Brl, 400TH). I don't hit the accelerator at all, and starts right up.
I've never had to crank it per extreme cold instructions.
Tony
Old 10-29-2024, 08:55 PM   #16
BDC90
Late update. Spent yesterday using Cliff's High Performance throttle shaft bushing kit. truck starts right up with 2 pumps on the pedal.
Old 10-29-2024, 09:59 PM   #17
PanhandleShantyman
Junior Member
PanhandleShantyman's Avatar
I'll second geezer#99's comment about more base timing. If your truck has rusted/frozen vacuum advance like mine, it'll go a lot better with +12 or so to initial timing.
When I first got my truck I spent so much time fiddling with/worrying about carburetor bogeymen, but as I learned more I realized almost every problem I had could be solved with a timing light. Vacuum gauge sorted out the rest of it. Almost everything I did with my carburetor (except for cleaning out debris) was unnecessary.
One exception, when I got it the choke was straight out WIRED into a mid position because the thermostatic coil was busted, it did start better when I made the choke functional again. It just required replacing the auto choke part. That was a pain because on my '69 the auto choke assembly bolts in around that oven coming off the exhaust and it was super corroded and the bolt snapped off and I had to drill it out. But in theory anyway, not a complicated fix...
anyway yeah I'd echo that if the choke works and the timing is set with decent advance, for my old truck that and a new set of spark plugs was all it took to fix the cold start problems.
PanhandleShantyman is offline   Reply With Quote
Old 10-30-2024, 01:29 AM   #18
Rust_never_sleeps
Nice. I did mine as part of a rebuild, so I couldn't tell how much improvement came from that piece, but it was pretty sloppy
