09-10-2024, 04:36 PM | #1 |
A/C System
So I'm needing some advice. I have a 71 cheyenne super with factory air. The system is complete. The only thing I've replaced is the compressor which was missing when I bought the truck. I'm debating fixing the factory air system or replacing it with a vintage air system. Any thoughts?
09-10-2024, 06:59 PM | #2 |
Re: A/C System
I like similar-to-factory air. I went with Original Air. I want a functional glove box and functional engine compartment evaporator casing and blower. Here is my experience. https://67-72chevytrucks.com/vboard/...d.php?t=790246
09-11-2024, 07:49 AM | #3 |
Re: A/C System
In my experience, the compressor is the weak link in the factory system.
If you truck is mostly original I would try to retain the factory system and possibly convert to a new Sanden compressor. The vintage air will get rid of the fiberglass box on the firewall and everything packages nicely under the dash. The vintage air system I had worked great and I will definitely install again, but not in an 'original' truck. |
09-11-2024, 10:44 AM | #4 | |
Re: A/C System
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
09-11-2024, 01:28 PM | #5 |
Re: A/C System
Kind of in the same boat, My compressor went out in mine and on the fence of rebuilding the stock compressor or buying a new compressor. Really want to keep the factory look.
This is the compressor I’m looking at https://www.oldairproducts.com/produ...=p124208-o2335
Doug 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US |
09-11-2024, 01:29 PM | #6 |
Moderator
Re: A/C System
I always go with factory AC when it’s complete. I use an A12 replacement compressor which fits the factory brackets. I use R12 as the system is designed for and have zero problems that way and enjoy ice cold air in 110 degree heat.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
09-11-2024, 03:24 PM | #7 |
Re: A/C System
I use R12 in all of my vintage vehicles. It's still fairly easy to locate.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
09-11-2024, 11:03 PM | #8 |
Who Changed This?
Re: A/C System
^ I bought a 30# tank at Pep Boys just before one had to have a license to buy it. I went to CostCo just before that, only to find that some guy had just bought the last two pallets. My tank is pretty much empty after all those years. Where are people finding it, these days?
09-12-2024, 07:35 AM | #9 |
Re: A/C System
Carlisle always has some available. I have my EPA 609 cert, but nobody ever requires me to show it when purchasing it there. I have quite a few of the 14 oz cans right now to top off the systems if needed.
09-13-2024, 12:19 PM | #10 |
Re: A/C System
I converted my stock a/c over to a swap meet 605 compressor, new ebay condensor and late model evaporator. Blows 45* at vent outlets easy to do a little mod here and there but still works great allso purchased an a/ac line kit from old air .Going on 3 years not 1 problem
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
09-17-2024, 04:48 PM | #11 |
Re: A/C System
I'm looking into the same thing with my 71. Most of the system is gone but the box with evaporator is still there. It has been left open to the elements for 30+ years so will require all new parts. The only thing I'm worried about is mounting brackets that will work with the headers.
1971 Cheyenne, The Blue Jay. The Blue Jay build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=516989 |
09-18-2024, 08:55 AM | #12 |
Re: A/C System
That shouldn't be a worry. On my 350 with a Sanden compressor, I used the standard Vintage Air bracket with a spacer and longer bolt to secure the bracket to the front header bolt hole. That's the spacer behind the #2 spark plug wire. Actually, you can see where I used two spacers there.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 09-18-2024 at 09:20 AM. |
09-18-2024, 10:14 PM | #13 |
Re: A/C System
Nothing wrong with aftermarket systems, but I prefer original.
09-24-2024, 12:50 PM | #14 |
Re: A/C System
What is the going rate per pound for R12?
09-24-2024, 01:35 PM | #15 |
Moderator
Re: A/C System
I see it on OfferUp, marketplace, etc for around $20 a can. That’s about the same price as r134 around here. I’ve stockpiled it for years and have more than I’ll ever need should I buy more classic vehicles. Swap meets are a great place to find it for even less.
09-24-2024, 02:04 PM | #16 |
Re: A/C System
If anyone here is going to swap over to aftermarket, I need a left evaporator cover in good condition. The engine fire cooked the cover closest to engine and I will need to replace.
09-24-2024, 02:08 PM | #17 | |
Re: A/C System
On another note, the stock systems don't cycle, do they? As for 134a prices, our local parts stores have it for around $12, and I see where it's $9.98 at Wal-Mart. I bought a 12-pack a few years ago at Sam's Club for $50-something. It's now $100. I wonder if a lot of that increase is federal taxes???
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
