Old 09-12-2024, 01:12 AM   #1
AntiGov
AntiGov's Avatar
New shoes
For the crew
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 09-15-2024, 10:23 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: New shoes
Those should look nice.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-15-2024, 07:55 PM   #3
kipps
Re: New shoes
Interesting -- I never realized anyone was making a 17-inch OE-appearance rim like that(I googled the tire part number).
The 17x7 size would definitely be useful for clearing larger front brake calipers on my project sometime in the future. As is, a certain axle/brake combo that I'd like to pursue won't fit inside the stock 16x6.5 rims.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 09-16-2024, 11:04 AM   #4
Shifty One
Shifty One's Avatar
Re: New shoes
Fine choice...I may be biased though...
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 09-16-2024, 09:48 PM   #5
AntiGov
AntiGov's Avatar
Re: New shoes
The 35 12.5 toyos on the truck now are on the stock 16 x 6.5 wheels
Nobody wants to mount that size tire on a 6.5 wide wheel . A buddy that works at a tire shop had to do it .....that was ten yrs ago ...tires are shot ....I love my caps ...wasn't sure what to do , then I found these ..
Went with the 17 × 8 .....better tire options
I'll post picks when I get them mounted up
Old 10-06-2024, 10:23 PM   #6
AntiGov
AntiGov's Avatar
Re: New shoes
Installed
Old 10-06-2024, 10:24 PM   #7
AntiGov
AntiGov's Avatar
Re: New shoes
Another
