Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 09-12-2024, 10:01 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Thinking about re wiring Who makes the best harness
What are guys using as far as re wiring harness kits. I’ve heard of American Wire and Painless. Are there any more out there. Would like to hear suggestions
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 09-12-2024, 10:05 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Thinking about re wiring Who makes the best harness
I used American Autowire..and will use them in the future ..very nice kit
Have a buddy that's used kwikwire on several of his..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-13-2024, 07:41 AM   #3
A1971Blazer
A1971Blazer's Avatar
I used the M&H upgrade kit on my '67 with great success.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 09-13-2024, 10:31 AM   #4
Sheepdip
Sheepdip's Avatar
My boy used Painless and it was straight forward and pretty simple or at least I thought so.
Sheepdip is offline   Reply With Quote
Old 09-13-2024, 11:00 AM   #5
1970 CST Short Wide
Senior Moment
I would like to know more about this one. What does a Upgrade Kit include
Who is M&H - Web Site ?
Pittsburg Ca
94565
Old 09-13-2024, 11:17 AM   #6
kwmech
I've used a Painless kit before and it was anything but, plus a lot of undersized wires. American Auto Wire has been my go to for the past 3 kits
Old 09-13-2024, 11:28 AM   #7
Boog
laying low
Boog's Avatar
Aaw.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-13-2024, 11:45 AM   #8
biketopia
I have an AAW for my project. My brother installed one of there kits in his 70 Camaro and prefered it over the previous Painless kits he's used. Some of the "update" stuff is modern blade type fuses and relays for headlights.
https://67-72chevytrucks.com/vboard/...d.php?t=642579
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 09-13-2024, 04:19 PM   #9
LS short box
I used Painless on my hot rods that needed a total rewire. They worked well. I used the 21 universal kit. Not the direct fit kits.
Old 09-13-2024, 07:00 PM   #10
HO455
HO455's Avatar
Are you doing a plug and play stock replacement or do you have major changes in mind?
RIP Bob Parks.
Old 09-14-2024, 01:07 AM   #11
1970 CST Short Wide
Senior Moment
My Big ? Is I have Dakota Digital, Vantage Air, A1 Power windows, LS1 Computer which all have there own harness. So what am I really Re Wiring
Pittsburg Ca
94565
Old 09-14-2024, 09:37 AM   #12
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i built a custom truck using a squarebody drivetrain with a 51 international as the body. I used American Auto Wire and the harness is great and easy to install
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-14-2024, 10:00 AM   #13
A1971Blazer
Here's a link to the website. https://www.wiringharness.com/
The upgrade has the ATO blade type fuses, it also includes several extra high amp fused circuits and an additional heavy gage feed wire into the fuse block to feed the additional circuits.
1967 C10 Step side
1968 C10 Step side
Old 09-14-2024, 04:33 PM   #14
LS short box
The LS ECM will need 12 volts constant and 12 volts in start and run when you turn the key. Your LS harness should include a fan relay and fuel pump relay.
I assume you will need a relay for the power windows.
Same with the AC circuit.
Gauges I'm thinking 12 volts in key on and run. Check with Dakota if it needs a constant 12 volt.
You have so much aftermarket stuff a direct fit harness would be a waste of money if its a lot more money than a universal kit IMO.
I love to hide wires. So on my 68 project I moved the Painless fuse block away from the fire wall and welded the hole shut. Then made a small hole and ran the chassis wires forward and back along the frame rail.
See pics.
Old 09-14-2024, 11:51 PM   #15
1970 CST Short Wide
Senior Moment
See pics.
You get What I’m saying. Maybe if I call AAW they can help. Nice Pics,love the hidden look. Here’s mine
Pittsburg Ca
94565
Old 09-15-2024, 04:14 PM   #16
LS short box
Thanks for the kind words.
In regards to the ECM harness I punched a hole in the fire wall behind the right cylinder just low enough so I missed the heater box. I mounted the ECM and fuse holder behind the glove box. Had to section the glove box a bit to make room.
In the pic of the right hand side of the engine you can just see the Painless fuse holder. That wire goes to the fuse block.
Just for fun a pic of my latest 80 Camaro with a LS3 swap. Again tried to hide as many wires as possible.
Old 09-15-2024, 04:58 PM   #17
mongocanfly
In your original message you didnt really specify what you needed a harness for.
so alot of assuming took place
Ive got a mixture..
My LS is running a PSI harness..the LS needs its own dedicated harness, but is easily tied into the truck harness...my 81 still has the factory harness on the truck side
My other truck also uses a PSI for the LS, but the truck side is the AAW..
The aaw harness can be ordered by how many circuits that you need..
If you need the truck side , make a list of all your electrical, I'm sure whoever you decide on would be happy to direct you to what you need
If your needing the LS harness ,there are several good ones on the market..my only complaint on the PSI is the harness is to short to allow the ecm to be mounted under the seat... BP makes their harness longer so it can be hidden under the seat..I'm using BP on my next one
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-15-2024, 08:38 PM   #18
LS short box
On my LS swaps I've used Speartech and Howell with both suppling a ECM with a base tune and wiring harness. If you send them your engine specs/trans details they can load a program that will get you running.
One thing I have gone away from on the last few LS swaps is the plastic "convuluted" wire cover and have been using the plastic braided wire cover. I get the generic stuff from Summit.
Hey Short Wide. I would look into moving the air filter so when your fans turn on they won't push air into the intake. Maybe it won't be a problem?
Company in WA state Intakehoses.com has a huge selection of rubber and alum tubing.
Old 09-15-2024, 11:27 PM   #19
1970 CST Short Wide
Senior Moment
Lots of good input. I’m not up on wiring or reading wiring blueprints. I have a stand alone harness for the LS that I bought years ago from Hot Rod Harness’s in LA. The A1 Electric window kit has its own harness as does the Dakota Digital Dash so I’m GUESSING I’d be just re wiring stuff like Lights and radio ?? Maybe I need to re think this
Pittsburg Ca
94565
Old 09-16-2024, 05:25 PM   #20
LS short box
Just FYI. I suck at wiring. If I can figure out the wiring you can. LOL.
Old 09-17-2024, 03:30 AM   #21
REDROCKER652002
My son and I rewired his 69 when we first bought it. I started with Painless and found that there were a lot of wires mounted to the same place on the fuse block and the instructions were very difficult. I looked into more options and found American Auto Wire to be the best. We had some grounding issues, but that was on me and not running the proper grounds to the proper places. Once I got that worked out, it all seemed to work out really well.
I have since "acquired" my dad's 56 Belair when he passed. None of my brothers wanted it so I took it over. It has been redone somewhat, but I might rip all the wiring out and use the AAW kit for that as well.
REDROCKER652002 is offline   Reply With Quote
