Old 09-10-2024, 04:36 PM   #1
wayneharron
A/C System
So I'm needing some advice. I have a 71 cheyenne super with factory air. The system is complete. The only thing I've replaced is the compressor which was missing when I bought the truck. I'm debating fixing the factory air system or replacing it with a vintage air system. Any thoughts?
wayneharron is offline   Reply With Quote
Old 09-10-2024, 06:59 PM   #2
dmjlambert
dmjlambert's Avatar
Re: A/C System
I like similar-to-factory air. I went with Original Air. I want a functional glove box and functional engine compartment evaporator casing and blower. Here is my experience. https://67-72chevytrucks.com/vboard/...d.php?t=790246
Old 09-11-2024, 07:49 AM   #3
Jason Banks
Jason Banks's Avatar
Re: A/C System
In my experience, the compressor is the weak link in the factory system.
If you truck is mostly original I would try to retain the factory system and possibly convert to a new Sanden compressor.
The vintage air will get rid of the fiberglass box on the firewall and everything packages nicely under the dash. The vintage air system I had worked great and I will definitely install again, but not in an 'original' truck.
Jason Banks is offline   Reply With Quote
Old 09-11-2024, 10:44 AM   #4
MARKDTN
Re: A/C System
What he said.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 09-11-2024, 01:28 PM   #5
DA71Grande
DA71Grande's Avatar
Re: A/C System
Kind of in the same boat, My compressor went out in mine and on the fence of rebuilding the stock compressor or buying a new compressor. Really want to keep the factory look.
This is the compressor I’m looking at
https://www.oldairproducts.com/produ...=p124208-o2335
Doug
71 Sierra Grande C25
16 Sierra 2500HD All Terrain
23 Chevy Tahoe Z71
https://paypal.me/digdug7131?locale.x=en_US
DA71Grande is offline   Reply With Quote
Old 09-11-2024, 01:29 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Re: A/C System
I always go with factory AC when it’s complete. I use an A12 replacement compressor which fits the factory brackets. I use R12 as the system is designed for and have zero problems that way and enjoy ice cold air in 110 degree heat.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-11-2024, 03:24 PM   #7
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: A/C System
I use R12 in all of my vintage vehicles. It's still fairly easy to locate.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 09-11-2024, 11:03 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: A/C System
^ I bought a 30# tank at Pep Boys just before one had to have a license to buy it. I went to CostCo just before that, only to find that some guy had just bought the last two pallets. My tank is pretty much empty after all those years. Where are people finding it, these days?
~Steven
Simi Valley, CA
Old 09-12-2024, 07:35 AM   #9
1970cstblazer
Carlisle always has some available. I have my EPA 609 cert, but nobody ever requires me to show it when purchasing it there. I have quite a few of the 14 oz cans right now to top off the systems if needed.
Old 09-13-2024, 12:19 PM   #10
kaycee
kaycee's Avatar
Re: A/C System
I converted my stock a/c over to a swap meet 605 compressor, new ebay condensor and late model evaporator. Blows 45* at vent outlets easy to do a little mod here and there but still works great allso purchased an a/ac line kit from old air .Going on 3 years not 1 problem
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 09-17-2024, 04:48 PM   #11
JamesRKing72
JamesRKing72's Avatar
Re: A/C System
I'm looking into the same thing with my 71. Most of the system is gone but the box with evaporator is still there. It has been left open to the elements for 30+ years so will require all new parts. The only thing I'm worried about is mounting brackets that will work with the headers.
1971 Cheyenne, The Blue Jay.
The Blue Jay build thread-
http://67-72chevytrucks.com/vboard/s...d.php?t=516989
JamesRKing72 is offline   Reply With Quote
Old 09-18-2024, 08:55 AM   #12
MikeB
MikeB's Avatar
Re: A/C System
That shouldn't be a worry. On my 350 with a Sanden compressor, I used the standard Vintage Air bracket with a spacer and longer bolt to secure the bracket to the front header bolt hole. That's the spacer behind the #2 spark plug wire. Actually, you can see where I used two spacers there.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 09-18-2024, 10:14 PM   #13
davischevy
davischevy's Avatar
Re: A/C System
Nothing wrong with aftermarket systems, but I prefer original.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 09-24-2024, 12:50 PM   #14
68 C10 Driver
Re: A/C System
What is the going rate per pound for R12?
68 C10 Driver is offline   Reply With Quote
Old 09-24-2024, 01:35 PM   #15
leddzepp
Moderator
leddzepp's Avatar
Re: A/C System
I see it on OfferUp, marketplace, etc for around $20 a can. That’s about the same price as r134 around here. I’ve stockpiled it for years and have more than I’ll ever need should I buy more classic vehicles. Swap meets are a great place to find it for even less.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-24-2024, 02:04 PM   #16
PbFut
Re: A/C System
If anyone here is going to swap over to aftermarket, I need a left evaporator cover in good condition. The engine fire cooked the cover closest to engine and I will need to replace.
PbFut is offline   Reply With Quote
Old 09-24-2024, 02:08 PM   #17
MikeB
MikeB's Avatar
Re: A/C System
Yes, if you can can keep the stock system working, I doubt any aftermarket system will work as well. Actually, they may cool as well, but I've found the controls and wiring to be kludgey on some.
On another note, the stock systems don't cycle, do they?
As for 134a prices, our local parts stores have it for around $12, and I see where it's $9.98 at Wal-Mart.
I bought a 12-pack a few years ago at Sam's Club for $50-something. It's now $100. I wonder if a lot of that increase is federal taxes???
Mike
