Old 09-11-2024, 02:28 PM   #1
AsianBlazer
Active Member
AsianBlazer's Avatar
ARB AirLockers F/R 71 K5
Hello,
I'm considering ARB Air lockers for my front diff, a Dana 44, and my rear diff, a corporate 12 bolt. I believe they are both bone stock internally. Is there a simple way to determine what gearing they have to pick the correct ARB set up to order?
Mike
AsianBlazer is offline   Reply With Quote
Old 09-12-2024, 12:24 AM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: ARB AirLockers F/R 71 K5
If the 44 still has the small ratio tag bolted to the front cover it will tell you. If not you can pull either cover and look at the ring gear. It should have the pinion and ring gear teeth numbers etched or stamped on it. For example 3:73 should read 41-11, I’ve seen them stamped the other way too; 11-41 either way if you do the math from there you’ll know what you’ve got.
Tyler
Old 09-13-2024, 09:33 PM   #3
AsianBlazer
Active Member
Thumbs up Re: ARB AirLockers F/R 71 K5
Perfect, thanks for the straightforward answer.
Old 11-21-2024, 01:42 PM   #4
Orange Crate
Orange Crate's Avatar
Why pull a cover? Then you have a big mess, plus scraping gaskets, sealant. Why not count the number of turns from the drive shaft to the wheel? A jack, a piece of tape and 15 minutes and you are done.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
