Old 09-16-2024, 04:26 PM   #1
Rg500gamma
Junior Member
K20 cab mount bracing with rotted cab mounts
I will need to install the braces to keep the integrity of the cab square before I remove it from the frame. Should I use the door hinges to the floor and the b pillar door lock to the floor as my reference and then left to right frame brace with a level on it to ensure it is square so I can pull it off the frame and leave at that to do the floor replacement ?
Love to hear what other methods have been used.
Rg500gamma is offline   Reply With Quote
Old 09-16-2024, 04:47 PM   #2
Roostre
Roostre's Avatar
Re: K20 cab mount bracing with rotted cab mounts
I'm in the process of replacing my entire floor right now. You can read about it in my thread. Below is a picture of my bracing. I went from inner door frame to inner door frame on both doors and then tied those braces together. I did that so I could put the doors back on and test fit with the braces still in place. I don't have it done yet, so I can't speak to the success of this bracing, but it doesn't appear to have moved.
Roostre is offline   Reply With Quote
Old 09-16-2024, 09:54 PM   #3
Fbks_Cruiser
Fbks_Cruiser's Avatar
Search for member May70. He has a good YouTube series on this very thing.
https://youtu.be/5ysUL5ZKtFk?si=cIyP5zaHPyo02TQ5
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 09-18-2024, 03:23 PM   #4
Rg500gamma
Junior Member
Thanks rooster. I also need to swap the roof along with rotted a pillar windshield posts . I got a roof with the a pillars and need to remove the outer skin as it has crew lights
The spot welds do look like they are internal. Ughhhhh
Old 09-18-2024, 03:42 PM   #5
Rg500gamma
Junior Member
I watched all of MAYCO's videos. I completely forgot that I could use stationary interior spots to base my bracing.
Sucks getting old.
Next is figuring out the roof and a pillar to roof posts.
Old 09-18-2024, 04:31 PM   #6
dagnabbitt
dagnabbitt's Avatar
Please post pics: I am going to do the same thing and have no idea where to start.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 09-18-2024, 07:23 PM   #7
CG
BlahBlahBlah
Wow you have to replace a lot of metal, floor, roof, windshield posts. Love to seem some pics of this cab you are working on.
Old 09-19-2024, 10:12 AM   #8
Rg500gamma
Junior Member
I will take some pics and post them.
The floor and the interior roof areas
Old 09-20-2024, 11:23 AM   #9
Rg500gamma
Junior Member
Having difficulty posting pics and I get a error of SECURITY TOKEN.. What is that about ?
I intend to cut half way down the rear window and then see how long I have to cut the pillars.
I have the Eastwood Rust Encapsulator that has the long hose with the 360 degree spray tip and will shoot that down all 4 remaining mounts I need to weld the new roof on..The inner roof is complete toast so I kill 2 birds with one task
Floor and bottom kick panels have to be addressed. Being a K truck I have the high hump floor
Old 09-20-2024, 11:32 AM   #10
Rg500gamma
Junior Member
I also intend to use the mesh protector on the cowl and I saw a few guys who added drain slots to the bottom A and B pillars and the rockers. Firewall is rust free.bottom of new floor gets Encapsulator and then scoffed with 220 and a few coats of base color . I may do the same with the bed
Old 09-21-2024, 07:17 AM   #11
You need to resize you pictures to a smaller size before posting them.
