Leaky trans dip stick tube fix...
For my fresh TH350 trans I had to purchase one of the aftermarket chrome dip stick tubes and it has been nothing but a hassle. I constantly have a leak of sorts from the base where it goes into the trans. I have checked and replaced the rubber o-ring, adjusted the mounting bracket to insure it was straight into the hole, but still it leaks. Is there some fix out there? Should I just try and locate a factory tube?
thanks! |
Pennyless Fool
I had the same problem with my T400. My factory tube was slightly bent and didn't fit perfectly, it was at a bit of an angle. Dealership had them in stock 15 bucks with o-ring. You have to get someone that will look in the books.
"Who owns this car with the peace sign, the mag wheels, and four on the floor?" 67 Short Step 283/TH400/4.11 |
It is a horrible pain! My dipstick was too big to fit in the hole w/ an o-ring on it. It took some serious creativity.
If you have an o-ring & still leaks, then you need a rubber skirt. They are in the Help! section at most auto parts stores. Even if the salespersons say they do not have them, look anyways.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
went throught this mess for month's. ended up getting some COPPER plus sealant and cleaned the area and "gooped" it all over it! let it sit over a weekend to dry and it was sealed. not the prettiest seal in the market but it worked.
no longer have a ride, but still a fan! |
my gas saver
just had to do the same as superfly68. not the prettiest but it works.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
Merciless Butcher
I am compltely sold on Lokar dipstick tubes. I have never had on leak yet.
Your Bought And Sold....I Got Your Soul! |
When I put the dipstick tube back in mine I used a new o ring and coated it with black silicone, hadn't leaked yet.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
