Old 09-15-2024, 09:42 PM   #1
Bigryanh
67 C10 Ride Height
I bought a 67 C10 and it appears that the PO didn't lower it "correctly". It looks like the rear coils have had a torch applied to them, and I think the front coils have been cut. Oh, and it rides like ****!!!
I would like to use lowered springs for the rear, and I have 3" dropped spindles for the front. Before I order rear coils/blocks, and new front springs, I would like to baseline how low I am from stock. I would like to keep the ride height about where it is now or maybe an inch lower.
My measurements from the fender lip to the center of the front wheel is 18" for the front and 18.5" for the rear. Does anyone have measurements at stock ride height from the fender edge to the center of the wheel?
Bigryanh is offline   Reply With Quote
Old 09-16-2024, 02:19 AM   #2
Luke87gt
Re: 67 C10 Ride Height
Not a ‘67, but my ‘69 measures 20” from the wheel axis to the top of top of the fender arch.
It’s even front/rear which is odd because I thought these trucks had a slight rake stock?
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 09-16-2024, 07:16 AM   #3
hewittca
hewittca's Avatar
They do indeed have a rake from the factory. The rear wheel arch is also 2" lower than the front arch, so with the factory rake the distance from wheel center to top of the arch is the same front and rear.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 09-16-2024, 07:45 AM   #4
Lee H
Lee H's Avatar
Would help to measure from fender lip to center of hub. They way you can compare any vehicle as the tire and wheel size are not effecting the measurement.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is online now   Reply With Quote
Old 09-16-2024, 10:20 AM   #5
Bigryanh
Yes, that is where I am measuring from.
Old 09-16-2024, 12:27 PM   #6
Lee H
Lee H's Avatar
Got it, I see that now. For reference mine is 16” rear 15 1/2” front. 4” rear lowering springs, 2” drop spindles and 1” lowering springs for the front. Did not take stock measurements so I have no idea how much lowering I really got.
Old 09-16-2024, 05:09 PM   #7
Bigryanh
That is a good height. What components did you use to achieve that height?
Old 09-16-2024, 05:32 PM   #8
samert111
samert111's Avatar
I'm 16" in front and 16.5" in the rear to wheel centerline with stock spindles and 5" lowering springs in the back and 3" springs in the front.
samert111 is offline   Reply With Quote
Old 09-16-2024, 06:48 PM   #9
Lee H
Lee H's Avatar
Control arms, springs and drop spindles from CCP.
Old 09-17-2024, 01:04 PM   #10
Hugh in NC
Hugh in NC's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1726592339
My 1970 has 2 1/2 inch drop spindles in the front and 4 inch drop springs in the rear. Front measures 16 1/2 inches and the rear measures 17. Measurements taken with genuine Chevrolet Truck Legends tape measure.
Hugh in NC is offline   Reply With Quote
Old 09-17-2024, 02:54 PM   #11
Bigryanh
Great info, Thank you.
