Yesterday, 02:04 PM | #1 |
Painting my chassis.
I'm planning to do a rattle can semi-gloss black paint job on my soon to be sandblasted '87 GMC frame and chassis components and was hoping for recommendations on paint and type. Typically I used Rustoleum products, but I've had issues with paint incompatibility between their primer and their paint before. I've looked into Eastwood's Extreme Chassis Black Primer and Chassis black paint. It's expensive but seems to be good stuff.
Thoughts? Recommendations? If it makes any difference, the truck will be a driver, but since I've gone to the trouble of tearing it down this far and rebuilding both front and rear suspensions, I want to do a nice job. Thank you! -Marc. |
Yesterday, 02:23 PM | #2 |
Re: Painting my chassis.
You spell your name correctly, so it makes me want to contribute my opinion...with the price of rattle cans now, you might as well go Eastwood...I mean they named the company after Clint, so you know it's tough. Add to the fact that it will last much, much longer, Eastwood is the way I'd roll.
Marc aka 'Shifty
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
Yesterday, 04:37 PM | #3 |
Rustoleum is terrible IMO, seems to never dry, ever. I dig the crap out of the Duplicolor low gloss black, DE1634
give it a spritz
84' C-10 Custom Deluxe 97' & 98' C-1500 Silverados |
Yesterday, 05:27 PM | #4 |
The key to using Rustoleum is to NOT use the rattle cans but use the stuff in quart/gallons AND reduce it 1:1 with acetone. It will dry to the touch in less than an hour. Spray it with the cheap harbor freight purple gun, and throw the gun away when done.
Yesterday, 09:50 PM | #5 |
If I had a nicely sandblasted frame to work with, I'd be calling up hot-dip galvanizing shops to see if any of them would give me a good price on dunking the frame and its associated brackets. I'm told the price is similar to powdercoating.
I'd skip the oil-quench step, and paint the chassis with any cheap black paint. When the truck is finished, it would get a yearly November coat of Fluid Film or something similar for more rust protection. That would be overkill, but would be the ultimate chassis protection in my mind. I haven't actually done this though.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
Today, 12:34 AM | #6 | |
https://www.kbs-coatings.com/frame-coater-kit |
