Old 09-15-2024, 06:07 PM   #1
dmjlambert
dmjlambert's Avatar
1969 TH400 transmission kickdown setup
Hi folks,
I have a 1969 CST/10 with a 350 engine, Quadrajet, and TH400 transmission. The kickdown mounts on the Quadrajet back left stud and is pressed with the original press lever that mounts on the throttle assembly. When this was on the truck before engine overhaul, I didn't get a picture and the overhauler chucked the kickdown and said "you don't need that." When I drove the truck to the transmission shop and had them overhaul the transmission, I asked them about the kickdown, and they said "you don't need that." A few years went by and I connected a 12V source to a light switch, and the other terminal on the light switch to the transmission, and took it for a test drive. When I floored the gas pedal, I simultaneously flipped the light switch. I concluded "I need that." So, I bought the kickdown switch from a forum member and now I'm installing it. This is what it looks like when idle and when full throttle. Does this look like the correct setup and correct action on the switch?
Old 09-15-2024, 07:20 PM   #2
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: 1969 TH400 transmission kickdown setup
Here's mine, on my '70, but just the side view.
~Steven
Simi Valley, CA
Old 09-15-2024, 07:28 PM   #3
dmjlambert
dmjlambert's Avatar
OK it looks like on yours the half-round cut out on the presser foot straddles the bottom unused hole instead of like I have it straddling the accelerator rod hole. I will see if mine fits better that way. It seems like the presser foot should hit the switch in a more straight-on way. Your switch looks quite different.
Old 09-17-2024, 02:55 PM   #4
damnyankee36
damnyankee36's Avatar
Without looking at my build documentation photos, I believe the switch goes on top of the mounting bracket. That looks like it would solve your alignment issue if the actuator bracket was shaped different.
I am quite sure that's how I found it. Doesn't mean it's correct... I can't remember what that bracket looked like.
I'll look tonight.
1966 C10 Custom Cab Restomod (Sold)
1969 Camaro Z/28 (Keeper)
Current Build: 1968 C10 (Semi-Factory Restoration)
1983 Camaro Z/28 (Next in line, Keeper)
1951 3100 (2nd in line)
damnyankee36 is offline   Reply With Quote
Old 09-17-2024, 04:20 PM   #5
Steeveedee
Steeveedee's Avatar
AFAIK, this is original. Though I know that when my FiL had the engine rebuilt, the rebuilder swapped sides with the heads, as the temp sender is on the passenger's side.
~Steven
Simi Valley, CA
Old 09-17-2024, 06:37 PM   #6
damnyankee36
I'll look tonight.
My mistake. My switch was installed as yours is. I only have one photo of it installed and it doesn't show the entire setup. Just part of the throttle bracket is showing. I don't have one of what it looked like when the switch was engaged.
Sorry!
Old 09-17-2024, 07:46 PM   #7
Steeveedee
Steeveedee's Avatar
OK, I went and checked switch activation on my truck. The foot, as installed, is flat to the switch pushrod at WOT, though the pushrod wipes across the surface of the foot while it strokes. It doesn't come at it straight on. It's been working for as long as I've known this truck, but I wonder if it is right. Found the page (401); looks like it's mounted wrong. And the switch I have does look like the one in the manual, except it doesn't have the boot.
OK, edited AGAIN! Looking back at your side view pic, the foot is tilted compared to mine. SBC to BBC maybe is the difference? Maybe I should delete my stuff- it may be red apples to green apples?
~Steven
Simi Valley, CA
Old 09-17-2024, 10:15 PM   #8
dmjlambert
dmjlambert's Avatar
OK the majority I see seem to be half-round cut-out on the presser foot straddles the bottom unused hole and that puts it at an angle such that the presser foot wipes across the switch button and ends up fairly flat on the button when fully engaged. In addition to the pictures from this thread, this picture from FirstOwner69 seems set up that way.
So, I set up mine like this. I think it's going to be fine, and Steeveedee I think yours is fine. My engine builder and my transmission shop would say you don't need that. I put a little grease on the presser foot. I'm going to get around to replacing the stretched-out throttle return spring and connect it so it pulls from the water neck, then I will connect the switch electrically to the transmission and switched ignition-on power source. Thank you everybody for your responses.
Old 09-17-2024, 10:43 PM   #9
dmjlambert
dmjlambert's Avatar
I think page 401 of the assembly manual is just showing the switch flipped on its side to make the wiring clear, and it's just a sketch. There's other imaginary stuff there in the illustrations, such as the fuse box terminal next to the radio terminal as a place to plug in. There's no terminal there.
Old 09-17-2024, 10:58 PM   #10
Steeveedee
Steeveedee's Avatar
I think that you are right. I've made many drawings to ASME and ANSI and DoD standards so when I look at this stuff in the assembly manual I get confused. I'd expect better section views, but our trucks aren't spacecraft. Your "foot" looks just like mine at WOT, on the switch. Ain't rocket science, I guess. And yeah, I was thinking about some lube on that interface. I'll bet that the lube guy at the dealer had a list of things to lubricate. When I worked as a mechanic (not at a dealer), if I noticed a squeak, I would lube it.
~Steven
Simi Valley, CA
Old 09-18-2024, 12:23 AM   #11
FirstOwner69
FirstOwner69's Avatar
Do any of these help?
Jim
FirstOwner69 is offline   Reply With Quote
Old 09-18-2024, 06:46 PM   #12
dmjlambert
dmjlambert's Avatar
Yes and thanks Jim, that is very clear.
Old 09-18-2024, 09:55 PM   #13
FirstOwner69
You're welcome. Glad I could help.
Jim
kickdown, th400
