08-22-2024, 08:43 PM | #5001 |
Re: What did you do to your truck today.The 3rd chapter
Well done so far Mark, nice weld
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
08-23-2024, 01:13 AM | #5002 | |
Is the White stuff from TetraEthylLead?
08-23-2024, 09:09 AM | #5003 |
White stuff ? Not sure what you’re referencing.
Edit:Are you talking about the valve picture ? If so I think the specks are just reflection of the flash on the oil deposits
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
08-23-2024, 03:23 PM | #5004 | |
I haven't been able to get Gas with TEL in over 24 years. If that engine has been run in the last Quarter Century, it's probably not lead deposits.
08-23-2024, 08:54 PM | #5005 | |
But the heads aren’t worth fixing couple of worn guides so it would be to much to spend . The heads are 75cc smog heads so I’m looking for new ones
08-24-2024, 02:43 AM | #5006 | |
Good Hunting.
08-28-2024, 10:06 AM | #5007 |
It's been a while since I posted anything on the board. Have more been reading/searching.
Last friday I put in a new water pump , new thermostat, new fan clutch with 7 blade fan and finally a shroud. Never had the shroud on because the 5 blade that was on it was a 19" fan. To big for the shroud. Had some overheating problems on the hot summer days, so decided to change a few parts. Luckily the radiator was still okay. Anyway, now it stays cool again.
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb 1974 Chevy Camaro Z28 (Original) ------------------------- The Netherlands |
08-28-2024, 03:30 PM | #5008 |
Found the rattle in the back of my 72 . Not sure how this got in there other than the stake pocket maybe for some type of hold down for the slide in camper that truck had been in the bed since new but it’s a 3/8 inch toggle wing nut . I pulled it halfway out by hand but needed a pliers to force it out fully . I was spraying some Fluid Film around there and spotted it .
08-28-2024, 03:53 PM | #5009 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-28-2024, 05:11 PM | #5010 |
No nut on it . Truck originally came with an under bed tire carrier as per the spid but it looks like they removed it to put the bumper on it . It’s a slide bumper with a lot of bracing . Leaning more towards a tie down for the slide in camper
08-28-2024, 09:39 PM | #5011 |
Active Member
Got my cab back on finally
08-29-2024, 01:42 AM | #5012 | |
1968 C10 327, 3 speed manual, LWB stock height daily driver. 1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon. |
09-02-2024, 11:28 AM | #5013 |
I finally got my inner fender wells and side mirrors back from bodywork and color matching.
Really don’t like driving around without a hood, so things got crazy. I figured the hood needs a scoop and it’s gonna need a hole in it anyways, soooo.....
"If it ain't broken, fix it 'till it is!" |
09-02-2024, 11:32 AM | #5014 | |
I’m asking as I have the bottom trim to put on, and yours looks like the thicker edge of the trim is facing up.
09-02-2024, 12:00 PM | #5015 |
Factory original . Was an early takeoff
09-02-2024, 12:45 PM | #5016 |
09-15-2024, 02:10 PM | #5017 |
I just replaced both trailing arms on my '70 short bed. Old arms had rust holes and a big gap between c channels. Job went smooth with no problems. I would advise anyone doing this swap to spread the forward mounts to aid in reinstall. You can close it back up as you torque the bolts
I did discover passenger side park brake cable frozen with no movement. Fixed that. http://67-72chevytrucks.com/vboard/a...1&d=1726423284 |
09-15-2024, 10:26 PM | #5018 |
Got the rear fenders and steps really close to paint today, lots and lots of sanding!
09-19-2024, 01:31 AM | #5019 |
Woke up the ‘65 after a 15 year slumber! Looks like I’m gonna need a muffler.
'67 c10 '65 c10 |
09-19-2024, 08:35 PM | #5020 |
Well, I went to adjust rear brakes and noticed the drum full of rear end oil. I cleaned everything up and pulled the rear (12 bolt) cover and then axels to replace the seals. Got the seals replaced, new gasket on the cover and put it back together…all good there.
Whilst I was under there, I noticed the rear u-joint was loose. So, I again cleaned it up and replaced it. I ordered a rear brake hose and plan to replace it tomorrow. Sorry, no pics.
1972 GMC C1500 350/350 1965 Mustang 2+2 289 4spd, show-car 1965 Mustang Coupe 289 4spd, stoplight racer 1/2 dozen Wheelhorse Tractors |
09-19-2024, 08:36 PM | #5021 |
09-19-2024, 09:47 PM | #5022 |
Who Changed This?
I replaced the flex hoses on my truck back when I converted to front disc brakes. tommy3horse's post reminded me that those hoses are now ten years old. Every time I start my truck from now on, I'm going to stand on the brake pedal before I drive it anywhere. Best place for a hose failure would be in my driveway.
09-20-2024, 02:38 AM | #5023 |
At the body shop.
An hour well spent -
" That didnt make it any newer " " Dont antique the equipment " |
09-23-2024, 12:07 AM | #5024 |
It's been years since I've driven my 1970 GMC at night. I had forgotten just how bad standard sealed beams are. I did research here looking for LED headlights that folks here have used. I found the same LED headlights on Amazon last week for $105 without tax.
Headlight installation was straight forward. They fit perfectly into the factory headlight bucket and plug directly into the factory headlight harness. Although I did have to grind off a locating tab off of each headlight. These headlights also have 'Daylight Running Lights' option. I also purchased a DRL module to control the DRLs on these headlights. I'm using a one wire alternator. So I just tied into the factory wiring harness where the old voltage regulator plug harness exits the main harness. Both constant 12v (red wire) and switch 12v (brown wire) are there to use. According to the seller on Amazon these LED headlight don't draw many amps. The low beams draw about 1.4A each on and when on high beams around 2.2 amps. So on low beam current draw is about 3 amps and on high beam current draw is about 9 amps. I don't see any need to use relays for this setup. I should have upgraded to these headlights years ago. The difference between the old sealed beam headlights and these LED headlights is just amazing. LED Headlights DRL Module - Made in the USA Headlights: Off Daylight Running Lights Headlights: Low Beam Headlights: High Beam BTW - The Cold Case radiator I installed about two weeks ago fit perfectly without any mods. Rumor has it this old gas station, just outside Oatman AZ on old Route 66, was the inspiration for the gas station in Disney's Cars movie. This photo was taken before installing the LED headlights.
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
09-23-2024, 12:28 AM | #5025 |
'68 C/10 Stepside.
I found I was losing gasoline vapor out of the Fuel Line connector at the Fuel Level Sender junction. Last night I tightened it up. I cleaned up some old teflon tape that seems to have dissolved. I had a new roll of the Yellow Teflon tape recommended for Natural Gas connections, but I wasn't sure if it was any good with the Ethanol they're foisting on us. So I went with Metal-on-Metal. Added a 5 gallon jerry can of 87 octane, as I had let the fuel level get way down [1/8th tank] so gas wouldn't spurt out while operating, as it did when Full. I'll top it off later and hopefully won't get gas fumes in the cab anymore.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 09-24-2024 at 11:48 PM. Reason: won"t Go Advanced to load pix |
