07-19-2024, 09:14 AM | #26 |
Re: 1968 redo
Subscribed!
Cool truck Can’t wait to see more pictures
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
07-22-2024, 03:39 PM | #27 |
Re: 1968 redo
Great project, I will be following for sure!
08-27-2024, 09:18 PM | #28 |
Junior Member
Re: 1968 redo
Well it’s been 13 years and I am picking up where I left off. Put the truck on jack stands, pulled the brake drums and master cylinder. Got new brake shoes and cylinder on right rear today. Gonna do left rear tomorrow as well as replacing front wheel bearings, races and seals. Master cylinder will be in tomorrow with the front wheel cylinders and shoes. I was planning on taking it down to the frame, but it’s in such good shape I have reconsidered. By the way, i had to pull the hubs off the front because they are riveted to the brake drum. Does this indicate that my Grandpa never had to replace brakes on this truck? 71,000 original miles.
Joey |
08-28-2024, 01:46 PM | #29 |
Re: 1968 redo
Riveted front drums just mean that your drums are original.
Job well, done, so far!!! Taking something all the way down can be a bad thing, depending. Since you had a 13 year lull in your work...you understand. Fix what you can, when you can, keep it roadworthy as possible. My 68 has been apart since mid 80's, but I have all the old and new parts for it. I like original pickups, but never see a problem with a V8 swap. Carry on!!! |
08-29-2024, 12:07 AM | #30 |
Junior Member
Re: 1968 redo
Today, we replaced the wheel cylinder and shoes. I picked up a new master cylinder, front wheel cylinders, and bearings for the front. I'm a little disappointed that everything is made in China. I am in such a rush, I don't have time to search for parts. I wish I had planned ahead and found some NOS parts. We ground the rivets off of the drums and the hubs came loose. My Daddy turns 81 in a couple of days. Neither one of us are in great shape and this humid Arkansas heat prevents us from putting in more than a few hours each day, plus I am still working 12 hour night shifts. It's a little over an hour from my house to his. My Dad was a paint/body man in late 60s thru mid 70s until he got hired at UPS. He retired from there. He has painted the hood, grill, cowl and fenders back when we first started. They look darn good. Gonna go back Saturday to replace the front brakes, hoses, bearings, and master cylinder. Gonna pull the heater core and take it and radiator to shop next. I will probably install an aftermarket a/c unit as well. Engine, transmission, power steering addition, more paint, buddy bucket reupholstering coming as will. I'll post some pics soon.
Joey |
09-01-2024, 11:27 PM | #31 |
Junior Member
Re: 1968 redo
Appreciate that advice. We replaced front bearings. We ground the rivets off the drums. Brakes are mostly done, but found a clogged line in the mid rear and had to order that part. Gonna put it on tomorrow, then put the wheels back on so we can push it outside and pressure wash 46 years of mud and gunk on the front end.
On another note I have verified that the 250 is the original motor and it has been rebuilt one time. cylinders are 60 over. I I am minus a head since the one I had was cracked like Humpty Dumpty, my uncle found one that would fit but it does not. It’s for a 261, and is apparently in demand for some 50s model engines. I’m gonna be looking for a cylinder head after I verify this engine is indeed a good one. If it’s not, I have other options. But, like I said, I want to keep it the way grandpa had it, within reason$$$$. Brake line and power wash tomorrow!!! Stay tuned, I’ll try to post some pics of the parts we painted on the front cap, to keep this thread interesting. P.S. May not be original, but a "numbers matching" 250.
Joey Last edited by Dude68; 09-11-2024 at 09:55 PM. Reason: Additional Info |
09-02-2024, 03:58 PM | #32 |
Junior Member
Re: 1968 redo
Brakes and bearings complete. Put wheels back on so we can pressure wash the front. Got some pics today, will post soon.
Joey |
09-02-2024, 07:38 PM | #33 |
Junior Member
Re: 1968 redo
[IMG]C:\Users\VHALITBrannJ\Pictures[/IMG]
Here is how the drum looks after grinding.
Joey |
09-02-2024, 07:42 PM | #34 |
Junior Member
Re: 1968 redo
Dont look like this is gonna work
Joey |
09-06-2024, 08:53 AM | #35 |
Re: 1968 redo
Very cool story about your truck. I understand about losing interest after finding something unexpected like the drip rail rust. Sounds like you've moved on to other stuff to keep the fire burning. Keep up the great work. Looking forward to more progress and pics.
09-10-2024, 02:22 AM | #36 |
Junior Member
Re: 1968 redo
A close up of the marking on the firewall. I am practicing loading pictures.
Joey |
09-10-2024, 02:42 AM | #37 |
Junior Member
Re: 1968 redo
I got a set of buddy buckets, gonna need paint, new foam and some covers. I need one of them iron mike handles as well. I just set them in here to see what they would look like.
Joey |
09-10-2024, 02:53 AM | #38 |
Junior Member
Re: 1968 redo
Here is the next step. I know I have bounced back and forth on the engine. Initially I wanted to change to a 350. I bought one with a 4 bolt main, had the heads redone, block checked, rebuilt lower end, and left it on a stand. It needs an intake, exhaust manifold or headers, and a hei. If I did this I was gonna change to an automatic transmission, something with OD, change the column, add ps. Something turned my sentimental switch on and I decided that I would just try to keep it like may grandpa had it, for memory's sake. It's an heirloom. So, the next step is gonna be to have this 250 checked out to see if it's ok. It ran up until I broke the timing gear. It has been sitting with the head off since 1992. If it is ok, I will find an appropriate cylinder head and get it going. If not, I will look at other options, one of those being the 350/auto plan. More pressure washing/degreasing the front engine/frame. Stay tuned.
Joey |
09-10-2024, 08:44 AM | #39 |
Re: 1968 redo
Pictures, fantastic.
09-11-2024, 03:51 PM | #40 |
Junior Member
Re: 1968 redo
A little degreaser and some more pressure washing. Took the alternator off, took some wires off solenoid. I think we will pull this motor out this weekend, clean up the fire wall and get it ready for paint.
Joey |
09-11-2024, 03:58 PM | #41 |
Junior Member
Re: 1968 redo
Here is a peek at the front cap. Dirt dobbers got on my grill.
Joey |
09-11-2024, 04:07 PM | #42 |
Junior Member
Re: 1968 redo
We have one fender left to paint. Went with a repop. This is the only sheet metal that will not be original to the truck. We plan on doing it after we pull the engine and get the fire wall painted. Gonna pull the doors off and paint them when we do this as well. The original inner fenders are done as well as the radiator support stuff.
Joey |
09-18-2024, 09:41 AM | #43 |
Junior Member
Re: 1968 redo
Dear fellow truck nerds,
The motor is out. After some help in the message board, I have verified that the motor is NOT the original one. It was an exchange. I was able to verify that it is indeed a 250, 1970 model by decoding the serial number stamped beside the distributor. It also has the dished pistons that you guys pointed out for further verification. We pulled the motor and transmission. Removed transmission, bell housing, flywheel from motor. Pistons are out, rings removed and cleaned the grooves. There is a faint groove at top of cylinders. Can't hardly feel it. Gonna have a motor guy look at it and see if it needs boring out. I also located a head that has supposedly had a recent valve job. Casting number 331184, 72.76 cc chamber volume. We will start working on the firewall soon. I am getting better with uploading pics, so I will try to keep the visual aids coming.
Joey |
09-18-2024, 12:03 PM | #44 |
Re: 1968 redo
The tops of those cylinders don't look good, at all...
09-18-2024, 05:06 PM | #45 |
Junior Member
Re: 1968 redo
That’s where the groove is, we honed them and look better. Not sure if it’s gonna need to be bored out.
Joey Last edited by Dude68; 09-18-2024 at 05:09 PM. Reason: Added info |
09-19-2024, 11:38 PM | #46 |
Junior Member
Re: 1968 redo
We are not doing a frame off restoration. We decided to clean up the frame and apply Eastwood rust encapsulator. We brushed this on today. Not sure what to do with the control arms and stuff, covered in grease. I have scraped, degreased and pressure washed twice. There is still a lot of grease. If I had broken it down, I could have cleaned each piece individually, but we decided against this. Cleaning up the firewall and prepping for paint are next. Head will be here next week.
Joey |
09-19-2024, 11:45 PM | #47 |
Re: 1968 redo
That's an awfully nice truck, will be following along. I am partial to baby blue 68s. Keep reporting back to us ok?
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
09-19-2024, 11:57 PM | #48 |
Junior Member
Re: 1968 redo
I had planned on painting the firewall, last fender, and doors, installing engine and reassembling everything under the hood. After we completed this we wanted to put the front cap back on to get all of the pieces out of the wsy in the shop. Rust in driver side cowl and both vents will prevent us from reinstalling the front cap. We will need the fenders off to patch this, so front cap mounting will be delayed until all of this is patched. Welding patches in place will not be an option for us. Epoxying patches and blending in or using fiberglass are two options we are considering.
Attachment 2393383
Joey Last edited by Dude68; 09-21-2024 at 02:27 AM. Reason: correction |
09-24-2024, 10:47 PM | #49 |
Junior Member
Re: 1968 redo
We decided to cut the lower portion of the of the outer cowls out. We did not want to get into the vents or any of the fender mounting holes. We used a step bit to cut out the spot welds and air chiseled to separate. It worked out nice. We had both panels off in 10 minutes. Both panels were full of leaves. Vacuumed them out, wire brush and wheel to the inside areas. Rust kill applied as far as we could reach. Grinded down to shiny steel in areas with rust. Used a dremel to do a little dental work on the tiny holes. Washed them out real good and sprayed them with rust encapsulator. The driver side was bad, passenger side did not have any holes.
Joey |
09-24-2024, 10:56 PM | #50 |
Junior Member
Re: 1968 redo
The blower motor hole was bad. From 1:00 to 6:00 was rusted away, as well as the rail on the firewall. I could not stand it so I applied the rust kill, wire brushed it, put the grinder to it, and did some dental work on it with the dremel, then put some rust encapsulator over it. I left a small piece that I could have broken off attached so there would be something to attach a patch too. I have not decided how I am going to patch the lip of the firewall yet. I cut a half donut out of some sheet metal to apply to the blower motor hole. There were a bunch of small areas in the "gutter" area between the firewall and cowl that required some dental work as well. They were small enough to apply epoxy in.
Joey |
