Old 09-20-2024, 08:31 PM   #1
PbFut
Post engine fire clean up
As some of you know, I had a pretty good engine fire 3 weeks ago. Hagerty has been decent to deal with on parts and allowing for self repair. I have the front clip off, engine out and 95% of firewall items removed. I was messing with various cleaning methods but not coming up with anything that does not require a great deal of rubbing with blue scotch-brite. The soot from burnt plastic is really bad. Has anyone with fire damage found a solution? Paint on the body panels escaped heat damage as far as I can tell but the soot will not release. I am no using sctch-brite on exterior. Polishing compound is working as that seem to be the ticket. But areas under removed panels and firewall is really bad. Tunnel and distributor area go too hot. Will need wire brush strip and prime. I have not removed interior as yet. So all that to ask for tricks in washing off this soot?
PbFut is offline   Reply With Quote
Old 09-20-2024, 09:31 PM   #2
LS short box
Re: Post engine fire clean up
After you remove everything off the firewall, then use various diameter "roll lock" fiber discs on a die grinder or hand drill.
Old 09-20-2024, 10:07 PM   #3
PbFut
Yes for removing burnt paint, but what about areas not needing repaint? The fiber disc will put too deep of marks.
Old 09-20-2024, 10:31 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
The soot is likely chemically bonded to the paint via heat. I know you don't want to hear my solution. Sorry to see what a mess the fire made of your truck.
~Steven
Simi Valley, CA
Old 09-21-2024, 01:00 AM   #5
howzzzit
howzzzit's Avatar
Will wet sanding work?
howzzzit is offline   Reply With Quote
Old 09-21-2024, 12:42 PM   #6
PbFut
All Exterior paint except hood is good. I experimented with polish used when I painted. Unless I find some heat damage, not expecting to, a good wipe down with paint prep and polish with compound will get it gack to 100. Firewall will need full strip to metal. Right fender on inside is heat discolored. I think I can strip to the hood channel seam and be good. Liners need strip and repaint. Cleaning just puts a step in that is not needed since I'll strip anyway. No getting around that the firewall is toast.
Old 09-21-2024, 02:55 PM   #7
Rust_never_sleeps
Rust_never_sleeps's Avatar
I wondered about that bond to unprepped paint, glad it's not fused on there. We used to remove fresh graffiti from heavy equipment with Brakleen and a rag, but that crap wasn't applied hot
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old 09-21-2024, 08:01 PM   #8
3drburb
If you have a Dollar Store (cheap) nearby, maybe try some oven cleaner along with Ajax or Comet with the heavy duty green scrubbing pads.
3drburb is offline   Reply With Quote
Old 09-21-2024, 08:23 PM   #9
LS short box
For the firewall I was thinking using the roll lock discs. But yes if you have undamaged paint areas the roll locks would be too course.
Old 09-25-2024, 08:59 AM   #10
70STOVEBOLT
70STOVEBOLT's Avatar
Maybe try this?
https://www.amazon.com/Absorene-Eras...33467506&psc=1
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
Old 09-25-2024, 09:56 AM   #11
Jason Banks
Jason Banks's Avatar
70Stovebolt, that looks like a good thing to try. OP might also try a Mr Clean Magic Eraser/Melamine sponge. They are essentially a very fine sanding sponge.
Jason Banks is offline   Reply With Quote
Old 09-25-2024, 05:09 PM   #12
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Try soaking it in wd 40?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-25-2024, 05:19 PM   #13
daddymoo2
How about a pressure washing it and soap solution. Good luck.
daddymoo2 is offline   Reply With Quote
Old 09-26-2024, 01:32 AM   #14
PbFut
Originally Posted by 70STOVEBOLT View Post
I had not thought about those eraser sponges. Thanks for tip.
Old 09-27-2024, 10:40 AM   #15
RustyPile
RustyPile's Avatar
I've been following your thread and I find I find it quite amusing.. I feel really bad bringing you bad news.. I have some experience with fire damaged vehicles.. That black stuff is the remains of hot black smoke and burning particles.. The heat has bonded that stuff to the paint and it cannot be "washed off".. You will NOT be successful trying to "rescue" or save the paint, it is forever damaged.. Grind, sand, or otherwise remove the paint down to bare metal.. Treat the underlying metal and then apply any necessary fillers, primers, etc., and then apply color matched paint.. Feather it in with the surrounding undamaged area.
RustyPile is offline   Reply With Quote
Old 09-27-2024, 11:12 AM   #16
MikeB
MikeB's Avatar
Amusing???
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 09-27-2024, 12:34 PM   #17
PbFut
Originally Posted by MikeB View Post
Amusing???
LOL. I hope it was just a poor word choice. Rusty is correct, sort of. The black soot does come off if the heat in that area was not too hot. It goes from oily and easy to remove with soap and wash cloth to elevated abrasive needed, to burnt paint. The outside of cowl cover got too hot. Repaint required. Outside of fenders looks good so far. I was hoping to wire wheel inside fenders up to the hood channel but the channel is not acceptable. I will try to meet at the top corner but I am not confident. That means bringing the color out around to outside of fender and stop at trim. Bummer as the outside paint realy turned out well for driveway spray. I messed with AC cover yesterday. SOS on the really bad stuff. The smaller cover is really toasted. There is plenty room inside to try and reinforce with resin and some mat. Then experiment with the gelcoat. Why I am obsessed with the ac cover with all the other stuff looking at me I don't know. I just roll with what ever bugs me the most at this point. I don't really know if the cover is salvageable so I obsess until i figure it out. Then easier to move to next part. Then I don't lay awake all night thinking about different procedures.
Old 09-27-2024, 12:55 PM   #18
mr48chev
mr48chev's Avatar
Sorry but on that truck I am not understanding why you just don't just do it right and sand it down the same as if you were restoring it from scratch, and paint the whole firewall and stand back and tell yourself nice job and put it back together. With trying to cut corners you are never going to be happy with the results in the long run. In truth you will probably get it done faster by sanding it down and repainting the whole thing rather than dink around trying to save part of the paint.
My ongoing truck projects:
Old 09-27-2024, 09:42 PM   #19
PbFut
Yup, fire wall will go down to metal. The fire wall is probably the easiest part of the whole job. I used that photo because it showed all the levels of damage from burnt to metal to just sooty. It's all the little parts and other areas like door jambs. Respraying the truck doors forward is in the cards, but I'm hoping not to pull it. Just asking the group to see if there are tips or tricks is an interesting discussion. Looking for options is part of the fun. I openly spitball ideas simply as a study. Sorry if you pros are frustrated with my process. This truck is not a 60K restore. It's always been a nice driver and will remain such, nothing more. If I dink around finally coming to the conclusion of full strip and repaint, thats fine but driveway sprays are a different process to a full autobody spray both. If you are lucky enough to get panels looking good, a do over is something to avoid at all cost.
Old 09-27-2024, 11:30 PM   #20
RustyPile
RustyPile's Avatar
PbFut knows me pretty well, MikeB.. He knows that my amusement is NOT from his misfortune.. What amuses me is the many remedies you guys come up with.. WD-40, soap and pressure washing, and many other approaches, and none of them will work. That s**t is baked on and it will not simply wipe off with a household cleaner.. The paint on that firewall is totally ruined and PbFut, down deep, knows it..
PbFut, if you weren't half a continent away from me, I'd invite you to bring that truck to my shop... I'd break out my "heavy artillery" and that sooty mess would soon be a dusty pile in the floor.
