Old 02-11-2013, 02:33 PM   #1
JFetter
What do these wires do? Neutral/Safety Switch
Hello,
My reverse lights have not worked since I bought the truck. (78 K10, auto)
After tracing down the wiring, I found that my neutral safety switch is totally missing. New one on the way...
So I'm pretty sure the light green and dark green connector is for my reverse lights.
Then there are the yellow and purple/white, which have been connected together. This if for the start circuit?
Then that leaves this purple wire all by itself not being used. Does this belong on the neutral safety switch?
Thanks!
1978 K10
JFetter is offline   Reply With Quote
Old 02-11-2013, 03:33 PM   #2
rs72z
rs72z's Avatar
Re: What do these wires do? Neutral/Safety Switch
The 2 purple wires are the starter circuit. The yellow wires has been added. Does it go to the starter?
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 02-12-2013, 01:26 AM   #3
kustomrust82
kustomrust82's Avatar
i believe mine were yellow and purple, 82 dually. my coloum was worn out so it was hard to line up the shift to start it so i looped the safety switch. just have to remember to not staart it in gear lol
'82 c10 shortbed drag truck
'82 GMC 3500 Dually DD scrap truck
'55 Chevy 210 4 door sled
'65 VW Bug Rat Rod
kustomrust82 is offline   Reply With Quote
Old 02-12-2013, 10:39 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
79 auto
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 02-12-2013, 10:45 AM   #5
hatzie
Moderator
hatzie's Avatar
First image is the Backup light plug.
Not sure where the yellow wire came from... Got an extra ignition switch plug?
1978 PPL/WHT is Circuit 5 the start position on the ignition switch. PPL Circuit 6 goes to the bulkhead plug and then the start lug on the starter solenoid.
1979 YEL is Circuit 5 the start position on the ignition switch. PPL Circuit 6 goes to the bulkhead plug and then the start lug on the starter solenoid.
You can find the GM schematics in my sig.
BTW according to the schematics it shouldn't start.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 02-12-2013, 12:09 PM   #6
rs72z
rs72z's Avatar
I need to look at my 78 i dont ever remenber seeing a neautral switch with different color wires till now.
___________________
78 ccsb dually
5.3
4l60e
Old 02-12-2013, 12:40 PM   #7
rs72z
rs72z's Avatar
Not sure when they changed them but my 78 has 2 green wires.
Just now saw the post above, there's my answer.
___________________
78 ccsb dually
5.3
4l60e
Old 02-12-2013, 03:52 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
knew i'd seen yellow but couldn't find the 78 before,just took another pic
78 auto
John
Old 02-12-2013, 04:52 PM   #9
JFetter
Hmmm, the plot thickens.
So 78 has both wires purple, in the start circuit.
It's almost like a 79 steering column is installed?
I'm going to have to trace some of these down and let you know what I find.
Thanks guys!
1978 K10
Old 02-13-2013, 06:43 PM   #10
JFetter
Just an update: The purple wire that is not currently being used must have gone bad at some point an PO just left it there. He then ran a new yellow wire to the starter.
Just got my new Neutral switch, connected everything and success! We have reverse lights.
Thanks!
1978 K10
Old 11-29-2015, 12:01 AM   #11
HotRod C/10
HotRod C/10's Avatar
Bump for N2Trux
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 11-29-2015, 12:48 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by HotRod C/10 View Post
Bump for N2Trux
Thanks for the bump. I will be back under my dash soon.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-29-2015, 08:14 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
What I was able to determine after in depth investigation is the plug that I have loose doesn't go anywhere. It has a jumper built, so it goes no where.
Articles-
"Refining Sierra"
Old 09-16-2024, 11:55 PM   #14
kitsbeach
kitsbeach's Avatar
Originally Posted by motornut View Post
79 auto
I'm reviving an OLD thread because it has the good info...
My question is what holds the switch to the column? Can I buy the clips in motornut's picture?
Name:  1979 J2Gs 0178.jpg
I'm converting my 1980 C20 from manual to automatic and this is what my manual trans safety switch looks like. Seems I'll be able to transfer the plug with the purple and yellow wires straight from the manual to the new automatic switch and I will have Park and Neutral safety.
Name:  1980 C20 manual clutch safety switch.jpg
This is what the automatic trans switch looks like new from rock auto.
Name:  ACDELCO D2220C NEUTRAL SAFETY SWITCH.jpg
The wire for my backup lights is under the floor hump near the shifter. No sweat to extend those wires to the automatic switch but can I find a plug and re-pin it? Or will I have to just spice wires (not as pretty)?
Any clues would be appreciated
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 09-17-2024, 12:28 AM   #15
kitsbeach
kitsbeach's Avatar
Here's some pictures from a Haynes manual on the subject. Talks about screws but looks like I need clips of some sort for the screws to screw into.
Kitsbeach (Ken)
Old 09-17-2024, 09:48 AM   #16
RustyPile
RustyPile's Avatar
Those "clips" are called J-nuts, available at most hardware stores... Also here:
https://www.classicindustries.com/sh...parts/?q=J-nut
The neutral safety switch isn't something special, GM used it for years.. O'Reillys and other auto suppliers have them sitting on the shelf.
RustyPile is online now   Reply With Quote
Old 09-17-2024, 10:34 AM   #17
kitsbeach
kitsbeach's Avatar
Awesome..!! Thanks for that info it’s the little things that slow down some of these jobs and I like to be prepared ahead of time so the vehicle is off the road for the minimum amount of time.
I appreciate your help RustyPile great name by the way.
Kitsbeach (Ken)
Old 09-17-2024, 11:06 AM   #18
RustyPile
RustyPile's Avatar
I've been using that screen name for about 30 years.. Originally, it described most of my projects.. Here lately, given my age, it more describes myself.
Old 09-17-2024, 12:36 PM   #19
kitsbeach
kitsbeach's Avatar
I’m with you brother
Kitsbeach (Ken)
Old 09-17-2024, 04:40 PM   #20
Slammed84
Slammed84's Avatar
Just a tech tip-
If you don't care about the neutral safety switch being operational, you can use the yellow and purple wires for a kill-switch
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
Old 09-17-2024, 05:22 PM   #21
kitsbeach
kitsbeach's Avatar
I think I’d like the neutral safety switch. The reverse lights are lower priority but I’d like them too.
Kitsbeach (Ken)
Old 09-24-2024, 08:28 PM   #22
kitsbeach
kitsbeach's Avatar
I'm still struggling with this. Has anyone got better pictures of how the neutral safety switch is attached to an automatic column?
I've bought an assortment of J-nuts but cannot see how they would fit or attach to the rectangular holes.
The switch itself looks like it might go on if I had some kind of imbedded nut in there first.
Name:  Neutral safety switch cannot attach-1.jpg
It does seem a little proud though, with those extra tabs on it.
Name:  Neutral safety switch cannot attach-2.jpg
Also whatever fastener goes in there will need to be pretty short as there's not a lot of room for the shift tube to rotate.
My problem is that I am switching from a manual floor shift column to an automatic trans column and don't have anything to look at for reference.
Kitsbeach (Ken)
Old 09-25-2024, 01:24 AM   #23
kitsbeach
kitsbeach's Avatar
Thinking about it I might just be able to attach it with a hose clamp....
Kitsbeach (Ken)
Old 09-25-2024, 01:34 AM   #24
kitsbeach
kitsbeach's Avatar
Here is what the clips look like on a 1969 Camaro...these look more likely to work but are not right for our trucks...and I don't see any NOS/OEM clips listed anywhere.
Name:  1969 camaro neutral safety switch clips.jpg
Name:  another 69 camaro neutral safety switch with clips.jpg
Kitsbeach (Ken)
Old 10-12-2024, 10:16 PM   #25
kitsbeach
kitsbeach's Avatar
Just following up here to say I attached my neutral safety switch using a hose clamp. Just plugged it all in and it works.!
Name:  Hose clamp neutral safety switch -1.jpg
Name:  Hose clamp neutral safety switch -2.jpg
Name:  Hose clamp neutral safety switch -3.jpg
Name:  Hose clamp neutral safety switch -4.jpg
Kitsbeach (Ken)
