09-23-2024, 09:24 PM | #301 |
Re: 1962 chevy c10 update.
Had everything in place. Used a straight edge to mark where it would be flush with the frame rail. Then cut out 7/8 in out and welded together. It hard to do.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
09-24-2024, 10:04 AM | #302 |
Thanks. I think I may have seen that in another thread. If I ever do something different with my 62, I think I would rather do this then add the blocks under the mount on top of the frame.
Rob |
09-24-2024, 08:19 PM | #303 |
I didn’t like the look so I just modified it.
09-25-2024, 02:44 AM | #304 |
A nice structure, I like it very much.
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
11-11-2024, 10:43 AM | #305 |
Attachment 2403979Engine almost complete. Just did the first start and fired right off with 60lbs of oil pressure. Still have a few things to button up like power steering lines and a small exhaust leak. I have the exhaust dumped right now u til I come up way to get it to the rear. I’m open to suggestions.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 Last edited by 62 Barnfind; 11-14-2024 at 01:31 PM. |
11-19-2024, 08:29 PM | #306 |
Wheels came in today!
11-19-2024, 09:07 PM | #307 |
Nice! that's always a good feeling opening up those box's. I'm personally not into the big wheel look but can still appreciate the truck, can't wait to see it sitting on it's rubber.
11-19-2024, 10:03 PM | #308 |
I can’t either! I think the rear is going to be tight. I had 15x8 all around and wanted to change the look a little bit
11-23-2024, 08:49 PM | #309 |
Today I put the bed on to test the clearance on the wheels. It’s a little tight but it fits. I still think I need to roll the lip a little to get the extra 3/8 clearance.
11-24-2024, 12:16 AM | #310 |
How wide are those wheels?
I'm tucking a healthy amount of 17" rim, but they are only 7.5" wide. There sure isn't much room in the step side fenders.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
11-24-2024, 09:49 AM | #311 |
20x9 with 5in backspace. 1in on the inside and 3/4 on outside lip.
11-30-2024, 11:00 AM | #312 |
Yesterday I went and had the tires installed. The rears fit but touched on the outside lip. I had to cut 1/4 off the fender lip to get the look I was going for. Not they have plenty of room. I did a test drive and this is a totally different truck!
11-30-2024, 02:34 PM | #313 |
Looks good. I need to get one of those manual fender lip rollers sometime for stuff like that, they seem super useful but just don't need it very often.
11-30-2024, 02:56 PM | #314 |
I have a fender roller, but usually have better luck with a baseball bat or a piece of pipe.
You would need to be careful of the rods that help the fender keep its shape; the fender won't roll easily there. Because of the thickness of the metal, cutting is probably easiest. Looks nice! (though... I want lower...(grin))
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate Last edited by SkinnyG; 11-30-2024 at 06:35 PM. |
11-30-2024, 07:57 PM | #315 | |
12-14-2024, 11:49 AM | #316 |
Took my truck on a long drive yesterday to the alignment shop. It had plenty of passing power and the temp ran between 160-180. I decided that the exhaust is too loud for me. So I will be hunting for another set of muffles to quiet it down.
