Old 06-18-2024, 12:31 AM   #1
HoneyBeeMan68
anyone with 17" sliver 55 rallys on there stock height. c10?
I'm at the point of getting rims and tires now and don't what to go to 5 lugs, so with wilwood disc brakes up front and stock height. I'm having to go to 16, or 17 rims. Not a lot of rims to pick from. Is anyone running the sliver 55 rallys in 17 on there c10? Is there any issues running 17 on a 68 stepside 2wd? my other choice is american racing 23 rims in 16"
HoneyBeeMan68 is offline   Reply With Quote
Old 06-18-2024, 12:47 AM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: anyone with 17" sliver 55 rallys on there stock height. c10?
Here is my 72 C10 at stock height with 255/60 17 tires and 17 x 8 Torque thrust 11's. Other picture is the truck with same wheel & tire combo and a 2 1/2 dropped spindle up front and 3 inch spring out back. The 17 inch tires are the same overall height as the normal 235/75 15 rims/tiresthat came on the truck.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-18-2024, 08:27 AM   #3
HoneyBeeMan68
Thumbs up Re: anyone with 17" sliver 55 rallys on there stock height. c10?
thanks Already Gone! the pic helps out with the wheel spacing alot!!
Old 06-18-2024, 09:23 AM   #4
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
The wife has them on her 67 it's a fleetside though I'll have to see if I can get a picture. It might be a couple days b4 I can get a good pic it's in the garage right now waiting on some new tailights
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 06-20-2024, 11:33 AM   #5
67 twins
This is the best I can do for now. The tires are 245/70-17
Chris
Old 09-25-2024, 09:19 AM   #6
68isgreat
I'm 2/3 done frame off restoring my 68 step, and I'm leaving at stock height with 15" rally's. I put 31" BFG All Terrain T/A's on it, which not only looks awesome, like a slightly lower 4x4, but the taller tires seem to work well with my 4.11 gears also. Loving it so far. I looked at lowering it, but the rear lowered coil springs are thinner and ride quality suffers. Makes it pretty much useless as a truck, so I'm leaving it stock. But that's another thread entirely. I'll post pics when I get a chance.
68isgreat is offline   Reply With Quote
Old 09-26-2024, 06:25 AM   #7
I am using US Mags white wagon wheels 17x8 on all 4 with 265/70x16 tires. Stock height longbed.
