Old 09-20-2024, 04:12 PM   #26
leegreen
Re: No spark
does it run if you take a jumper wire from battery to distributor as was suggested ?
You have a stomp starter so the starter solenoid wires in harness are probably unused
I think I'd take the switch out and test it's function with a MM or test light. If it only has off and on, how many terminals does it have? 55-59 have more than 2. Where does your ACC connect?
leegreen is online now   Reply With Quote
Old 09-20-2024, 06:29 PM   #27
popeyestruck
Re: No spark
there are 5 terminals bat ,sol,acc,ign and ground and its a 2 position switch. The acc goes to a 6 position plug for fuel pump ,power seats,power locks,cruise,power windows and CB . They are just a source for 12 volt power. ive tested the ignition switch and only the Batt and AC get power. I tested the old switch that worked when removed and its the same way. I guess I'm missing something. I've rebuilt old harley switches that are 3 position where the 3rd run position is just an internal jumper bar but this is a 2position. I havent jumped the distributor direct from the battery yet. Not really ready to check that if I dont at least have power to the distributor
popeyestruck is online now   Reply With Quote
Old 09-20-2024, 07:34 PM   #28
leegreen
Re: No spark
do the colors you mention correspond to 1950s wiring ?
https://chevy.oldcarmanualproject.co...ring/index.htm
this is '55 truck from link above
Name:  Screenshot 2024-09-20 161836.jpg
pink here appears to be for accessories and dk green from ign1 to coil, violet from ign 2 to starter (does that energize the foot starter or something?)
this section is interesting,
Name:  Screenshot 2024-09-20 162651.jpg
this resistor, if you trace it back appears to take power from ACC through the resistor and to the coil and back to IGN. Maybe ign1, 2 is not switched inside the switch it is just a pair of connectors??
Post # 10 here by mr48chev hints at some knowledge here? and he posted the same diagram.
Old 09-21-2024, 09:01 AM   #29
popeyestruck
Re: No spark
OK . I put everything back together and I now have an energized pink wire. I dont know what I did. Might have been grounded or pinched wire or maybe it is a bad switch. I'm going to put the battery on the charger and try it in the morning. Dont want to rwsh low voltage going to the HEI
Old 09-22-2024, 08:02 AM   #30
popeyestruck
Re: No spark
IT RUNS!!!! Started right up . 235 is so quiet you can hardly hear it run. Got a little leak on the power steering line should just need tightening. I'll post a video if I can. Thanks to everyone
Old 09-22-2024, 10:28 AM   #31
dsraven
Re: No spark
Perfect. Good to hear. A video would be great.
Old 09-22-2024, 06:48 PM   #32
mr48chev
mr48chev's Avatar
Re: No spark
Cool Beans. Now we can look forward to that first drive video.
My ongoing truck projects:
Old Today, 10:52 AM   #33
popeyestruck
Re: No spark
Had my motor running and it blew a line for the canister oil filter. Looks like its just old and worn out. I bought new lines but I'm having trouble getting them to seat so one line drips. Its a compression fitting similar to a brake line. Is there something I'm missing when getting them to seal up other than just keep tightening?
Old Today, 11:20 AM   #34
dsraven
Re: No spark
snap a pic of what you have in a disassembled manner. sometimes there is a part missing.
compression fittings can be finnicky if overtightened as the inner part (ferule) starts to crush the part it bears down on and then it never seals properly. if it is a soft like, like the teflon tubing, there is a small tube that goes inside the soft line so it doesn't just keep crushing down the tube as the fitting is tightened. a few pics would help us see exactly what you have. I have also seen the compression fittings used on aluminum tubing, like the stock vortec 350 sbc oil cooler lines or the stock GM auto trans cooler lines, crush the aluminum tubing as the owner overtightened the fiting to try to stop a leak.
Old Today, 11:21 AM   #35
dsraven
Re: No spark
I have used the grease gun whip hoses for the stock 235 style oil filter cannister. available at hydraulic hose suppliers, napa etc
Old Today, 11:28 AM   #36
dsraven
Re: No spark
oh, sorry, you said compression fitting like a brake line. I assume you are talking about the flare style fitting if it is like a brake line. check the sealing surfaces on the fittings to ensure there is no groove or deformity and also the sealing surface on the flare of the tubing. sometimes just replacing the fitting with a new one stops the leak due to an out of round or deformed fitting. I replaced some of those fittings with pipe thread fittings and used grease hose with a connection on one end that allows the fitting to swivel. tighten one end into the engine block and use the swivel on the cannister end. just a thought.
Old Today, 11:33 AM   #37
popeyestruck
Re: No spark
I used these. It sounds like that is what I have . You tighten to the canister then tighten the swivel that pulls the swivel apart which seats the fitting. Not really a good system in my opinion. I got the top one to seal but the bottom has a drip. I'll just keep playing with it till it seats. Apart from that I have great oil pressure.
Old Today, 11:37 AM   #38
dsraven
Re: No spark
maybe a piece of crud in the fitting? I have loosened that style of fitting under pressure and allowed a small amount of fluid to escape, which self cleans the fitting sealing surfaces, then tightened to normal spec. if it still leaks i would try tightening a little more but not too much or the fitting simply deforms. if it still leaks maybe a new hose and fittings are in order.
Old Today, 11:38 AM   #39
vintovka
vintovka's Avatar
Re: No spark
Hose quality??
vintovka is offline   Reply With Quote
Old Today, 11:54 AM   #40
popeyestruck
Re: No spark
Yeah that what I'm doing tighten and reseat like you do with brake fittings in the morning. Hose quality is from jim carter so I'd guess good
Old Today, 12:20 PM   #41
vintovka
vintovka's Avatar
Re: No spark
I now suspect all parts as manufacturers are so limited and workers don't seem to care. Its strange to have to review the return policy on everything first.
