Old 09-17-2024, 09:54 AM   #1
popeyestruck
popeyestruck's Avatar
No spark
Motor turns over but no spark at the plugs. HEI dist with built in coil. Before I put gas into it I ran the starter to get oil up into the motor. The cotter pin that holds the foot start linkage hit the positive lug of the starter and it was smoking. Would this have caused a coil to blow? Starter circuit is all good. Ignition circuit is good. I'm going to check for power on the pink wire tomorrow and if I need pull the coils and check it
popeyestruck is offline   Reply With Quote
