Old 01-10-2024, 06:33 PM   #201
xr4tic
Re: Tremec TKX 5 Speed Transmission Installation
Thanks for this thread, this is definitely on my list of things to do eventually.
Is your motor in the forward or rear mount position?
To add to the swap info, if you have a newer bellhousing with the larger hole, you can use this adapter to reduce it, I used this on my manual 70 C10 to mount a Muncie M20
https://www.summitracing.com/parts/ADD-716078
xr4tic is offline   Reply With Quote
Old 01-10-2024, 06:35 PM   #202
pjmoreland
pjmoreland's Avatar
My truck came with a V8 originally (E in the VIN), so the engine is in the forward position.
pjmoreland is online now   Reply With Quote
Old 01-10-2024, 11:03 PM   #203
chipmaker 1985
Finished my install in the 6-banger position a couple weeks ago. The shifter clears the bench fine. Decided to make my own shifter and left it straight for now. I'll angle it to wherever is comfortable after I log some miles.
Thanks for the nice carpet. Mr. Patrick
chipmaker 1985 is offline   Reply With Quote
Old 01-11-2024, 12:38 AM   #204
pjmoreland
pjmoreland's Avatar
Excellent! Are you happy with how it drives?
Old 01-11-2024, 09:12 AM   #205
chipmaker 1985
Loving it from what I can tell so far. I've only driven it about 25 miles. I haven't had it properly aligned since the front end rebuild and still waiting for my 3-point belts to arrive. 1st-4th have been awesome, I get a little antsy in 5th gear speeds. Unfortunately I have kissed a metal dash before, I'm not willing to risk it, till she's safe-ish.
Old 01-11-2024, 10:56 AM   #206
Rickysnickers
Flipped
Old 01-11-2024, 12:41 PM   #207
chipmaker 1985
Originally Posted by Rickysnickers View Post
Flipped
Awesome! Thank you.
Old 01-11-2024, 07:30 PM   #208
Rickysnickers
Old 09-28-2024, 01:00 PM   #209
pjmoreland
pjmoreland's Avatar
I replaced the Race Tuning mid-shifter with one that Tremec recently started selling. It is a big improvement.
1) It has a much shorter throw
2) The centering springs are much stiffer which makes it way easier to shift from 2nd to 3rd
3) It incorporates a 5th-reverse shift inhibitor
4) It is half the price
Old 10-27-2024, 04:30 PM   #210
gringoloco
A guy with a truck
gringoloco's Avatar
Hey PJ, thanks for the excellent write-up! Taking notes, specifically on your shifter stick and the new Tremec mid-shifter.
How are you liking the TKX? My TKO has to come out because 1) it’s whiny and I’m tired of hearing it complain, and 2) I beat on it until it broke something inside the bellhousing this morning. Im thinking about upgrading to a TKX or maybe Magnum while it’s out, curious what your experience has been like with your transmission, especially shift quality and noisy-ness (not my TKO’s strong suit).
Thanks -Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-27-2024, 06:15 PM   #211
pjmoreland
pjmoreland's Avatar
Thanks -Chris
Hey, Chris. I don't have any experience with the TKO, but I'd say the TKX is pretty quiet. It does make a very slight high-pitch whine that I can hear when coasting. It's not distracting though. Shifting is reasonably smooth. The 1-2 shift can be slightly rough when the transmission is cold, but it smooths out after a couple of miles. I have found that the TKX doesn't really like to be shifted fast and aggressively. It likes a slight pause before shoving it into the next gear.
Old 10-27-2024, 09:09 PM   #212
xr4tic
Out of curiosity, what fluid are you using?
I found this on the ShiftSST site:
"TREMEC approves the following fluids for all of their 5 and 6-speed transmissions: TREMEC HP-MTF, Pennzoil Synchromesh, Dexron III/Mercon ATF (non-synthetic), and Mobil 1 ATF. We recommend the ATF fluid for break-in and the TREMEC or Pennzoil fluid thereafter."
I bought Mobil 1 ATF for mine to start with and was planning on Synchromesh for later, but haven't filled it up yet.
Old 10-27-2024, 09:27 PM   #213
pjmoreland
pjmoreland's Avatar
I am running ACDelco Synchromesh which is one of the fluids listed in the installation instructions from SST.
