Old 07-29-2020, 09:42 AM   #1
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
T5 swap & driveshaft length?
I picked up a T5 from an S10 that I plan on putting on my 67 C10 v8 truck that has a 3 speed in it now. Looking at what I need to make this work it looks like the T5 is about 3 3/16 in. Longer than the 3 speed (best as i can measure with the Tranny still in the truck)meaning I need a equivalently shorter driveshaft. After talking to the driveshaft shop & being quoted $350 to shorten my shaft, I started thinking.
The six cylinder trucks mount the engine & transmission further back in the chassis so a six cylinder 3 speed truck should have a shorter shaft. Well after measuring what I could it looks like the transmission crossmember in the 6 cylinder trucks sit somewhere between 3.4 & 3.7in. Further back.
I'm thinking this is close enough that a driveshaft from a 6 cylinder 3 speed truck might be just what I need. Anyone tried this before or would anyone like to comment?
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 07-29-2020, 01:05 PM   #2
gmc684x4
Re: T5 swap & driveshaft length?
I am surprised there is not a chart made up of the varies drive shaft lengths for our trucks
I am not there yet but looking at putting a 5 speed from a 96 c1500 into my truck build
gmc684x4 is offline   Reply With Quote
Old 07-29-2020, 03:19 PM   #3
typerr
I did the exact same swap of a WC T-5 into my 70 that originally had a 3 speed. I took exactly 3" out of the driveshaft but paid significantly less to have it shortened. I brought them the front half of the driveshaft with the u-joint and carrier bearing already removed.
typerr is offline   Reply With Quote
Old 07-29-2020, 09:03 PM   #4
jocko
jocko's Avatar
There's probably not a chart because every truck is different - the amount to cut is not simply the difference in trans lengths, it depends on the suspension, ride height, etc. Driveline shops generally ask for the straightline distance from the rear tailshaft HOUSING face (not the output shaft) to the center of the rear u-joint - as measured while the truck is weight-on-wheels. Then they do their math and cut - provides appropriate slip yoke engagement amount and ensures it won't fall out when the suspension is unloaded when one gets airborne over the RR tracks - or, more likely, binds it into the rear of the trans when the suspension is compressed (when one lands )
I've noticed that driveline shops (or at least the ones I've dealt with) don't tell me how long it's supposed to be after I give them my vehicle's measurements, until they have it in hand and start choppin. Probably a good business model or folks would be sending in their measurements, then chopping and welding at home. Personally I'd always use a trusted driveline shop, no matter HOW good I might think my welding is... They generally do a much better job cutting, welding, and balancing than someone who only does it every once in a blue moon - money well spent.
If you are measuring a ds from one someone else cut for their trans swap - and EVERYthing else is the same - ride height, tire sizes, rake, and of course trans & rear - you could probably get close enough to cut yourself and be ok. But I truly think it's worth letting an experienced driveline shop do it, in which case, knowing the exact length measurement they are going to cut it down to doesn't matter, they do it and you're good to go. I don't like spending $ or farming out work on my trucks either, but sometimes, it seems to be a good idea.
FWIW, $350 is only a little more than I paid about 10 years ago, but not much. Seems reasonable to me.
Old 07-29-2020, 10:21 PM   #5
Ultrasummer
I just got done doing this whole thing. I put a T-5 in. Once the engine and trans was in place, I then approached the drive shaft shop told them what I had. They asked me questions about certain measurements. I crawled under the truck, got all the measurements they asked for, and then they fabricated a new drive shaft for my application. Btw, my old driveshaft was a 2 piece. The new one is a one piece. $388.00 done....with piece of mind.
Ultrasummer is offline   Reply With Quote
Old 09-29-2024, 04:35 PM   #6
white67
Question I remover a Saginaw 3 speed to put in the t5. The splines are different 10vs 14 on the T5 Clutch plate for the Saginaw was 12 inch the one for the t5 is 9.5. Easiest way to fix this ?
white67 is offline   Reply With Quote
Old 09-29-2024, 09:15 PM   #7
jocko
jocko's Avatar
If I recall from when I did this, I went with a complete 14 spline Astro Van clutch/pressute plate/throwout bearing kit (I think it was an 11" clutch, but don't quote me on that).
Despite the author's mechanical incompetence, this thread might be of some help (the link to the 14 spline Astro clutch kit in Post #1 is long dead - but that's what it was a link to)
If not familiar with the potential different input shaft lengths (generally speaking if it's a Camaro T5, you're good - if S10 T5, input shaft is likely a little too long) - recommend take a look at post 1, here's an excerpt regarding the considerations if you have an S10 trans:
If S10 main case is confirmed and you have an S10 tailshaft housing, here are the things to do to make it work – the general idea is that you want to:
1. space the transmission and bell housing apart enough to compensate for the S10 T5’s input shaft being longer than your stock trans set-up while –
2. still making sure to provide proper trans-to-bell housing alignment (indexing) and -
3. still ensuring sufficient clutch hub spline and input shaft spline engagement and –
4. still ensuring sufficient engagement of the pilot shaft into the pilot bushing (I used a pilot bushing vice a pilot bearing, just one less thing to go bad in my mind, a bushing is a simple chink of metal rather than a mechanical marvel like a roller bearing – so I like simple – but that’s just me) and -
5. still allowing you to do all the above with a stock bell housing and regular old stock mechanical clutch linkage – no hydraulic release bearing or slave cylinder is required.
Some places sell spacers nowadays, you shouldn't have to make one yourself. Or, like I said, if it's a camaro trans (with an S10 tailshaft - truly the best of both worlds), all you need is the new clutch kit. Recommend using your truck's original bell housing, Camaro's bells induced a twist to angle the shifter toward the driver, I think..... It's been a while, but the details are in the link if you find it helpful.
Also bear in mind the difference in indexing ring diameters - this is why I had to build the special sized ring along with the spacer - it ensures centering of the trans (generally speaking the bolts don't do this as accurately as you'd think).
Good luck, it's a funs swap for the most part - but very worth the effort, fun to drive.
Old 09-30-2024, 10:22 PM   #8
white67
Do you have to use a spacer?
Old 09-30-2024, 10:24 PM   #9
white67
Did you need a spacer?
Old 10-01-2024, 07:42 PM   #10
jocko
jocko's Avatar
It depends on what your T5 was born in. If an S10, yes, that generally requires a spacer. In the case of a Camaro trans (ideally with an S10 tailshaft for forward stick placement in a bench seat arrangement), a spacer is generally not required.
I needed a spacer but none existed when I did this, so "kinda" designed one and had a machine shop make it - it was rudimentary. Before I was done, folks were reproducing them, so I wish I'd waited, but it worked great. My trans was from an S10 and I was lucky in that it was also a WC with manual speedo connection - a desirable and kinda rare combo, not one I was smart enough to seek back then, but fortunately stumbled into it. If I recall, I either picked it up at the Pomona Swap Meet or the LA Roadster show one year, a long time ago, in a galaxy far, far away.. Then I learned the stuff in the link above, usually the hard way, along the way of figuring out what I had and how to stuff it in the truck.
