Old 09-30-2024, 11:02 AM   #5
72c20customcamper
72c20customcamper's Avatar
Re: Before and after
Originally Posted by pjmoreland View Post
What is the size of your front tires? What is the width and backspacing of the front rims? If the tires are too big and the rims are outboard too much, they may hit the inner fender when you encounter dips in the road if you lower the front 4.5 inches. I had that problem with a 3.5" drop and 255/60R15 tires on 8" rims with 3-7/8" backspacing. The disc brake conversion I installed exacerbated this problem by shifting each wheel outward by 3/4".
15x7 3.75 backspace . Tires are 215/65 . The rims I had on it were 16x8 with 5-1/2 backspace came off my Tacoma tires were 265/70r16 and they never hit and they were real close to the fender lip . The kit I bought supposedly doesn’t add anything to the track width . I bought the CPP kit that uses the original ball joints and tie rods
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
