Old 10-01-2024, 01:44 PM   #1
jakewalter
jakewalter's Avatar
Rear camera installation
I am in the process of installing a rear camera for my truck camper.
I am working on my 85 K20 with an automatic transmission.
I need to tap into the backup lights.
Rather than run a wire back to the taillight I was wondering if I could tap into the wiring underneath the dash.
If anyone knows where the wires are I would appreciate the help.
Thanks so much,
Jake
1967 Chevy SBSS Bone stock
1974 Chevy Cheyenne 4wd long bed
1985 Chevy Scottsdale 4wd long bed
2000 Chevy 1 ton 4wd dually quad cab
2004 GMC Sierra 4wd Super cab long bed
jakewalter is offline   Reply With Quote
Old 10-01-2024, 07:13 PM   #2
kglowacky
Re: Rear camera installation
I'm only guessing on a 85 but my guess is it is the switch mounted on the steering column.. I am confident someone on this forum knows this answer.
kglowacky is offline   Reply With Quote
Old 10-01-2024, 09:05 PM   #3
geezer#99
geezer#99's Avatar
No wires needed.
Search for wireless back up cameras.
Some examples for you.
https://www.google.com/search?q=wire...ient=img&udm=2
Old 10-02-2024, 04:44 PM   #4
jakewalter
jakewalter's Avatar
Originally Posted by geezer#99 View Post
No wires needed.
That would be a good idea however I already bought a hard wired version.
Old 10-02-2024, 08:13 PM   #5
Bandit130
Bandit130's Avatar
Couldn't you tap into the backup light wires at the rear of the truck near the bumper?
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 10-03-2024, 07:07 AM   #6
Dead Parrot
2nd the idea of tapping into the Neutral Safety Switch. IIRC, it normally also handles the backup lights.
Is this main power for the camera or some kind of activation signal for one that is already booted up? It would kinda suck if you have to wait many seconds for the camera to go through a boot up cycle before you can begin moving back.
Dead Parrot is offline   Reply With Quote
Old 10-03-2024, 05:15 PM   #7
jakewalter
jakewalter's Avatar
Yes I can however I was hoping to connect the wire closer so I didn’t have to run it all of the way back.
I will have to check the neutral safety switch. That would be a great place.
[/quote] Is this main power for the camera or some kind of activation signal for one that is already booted up? It would kinda suck if you have to wait many seconds for the camera to go through a boot up cycle before you can begin moving back.[/quote]
The camera has a four pin plug. One of those wires controls the backup monitor. That’s the wire that needs to be connected to the reverse lights.
Old 10-07-2024, 03:49 PM   #8
Slammed84
Slammed84's Avatar
"The camera has a four pin plug. One of those wires controls the backup monitor. That’s the wire that needs to be connected to the reverse lights."
Any possibility you could post the schematics if any were included? I deal with analog cameras quite a bit at work, typically they need 2 wires for power, 2 wires for the video signal, so I'm wondering how there is a signal wire to fire the monitor for the camera in cab.
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
Old 10-09-2024, 09:46 PM   #9
Pontiac1976
Pontiac1976's Avatar
look up 85 column wiring diagram for your option on this sit
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 10-15-2024, 01:34 PM   #10
jakewalter
jakewalter's Avatar
I’m sorry for not getting back to this sooner.
My wife and I went on a camping trip in the upper peninsula of Michigan and had transmission problems.
We had to leave the camper up there at a friends house so it will be a while until I get back to the rear camera.
Thank all of you for your insight and advice.
It is really appreciated.
Old 10-19-2024, 08:28 AM   #11
Axle
Axle's Avatar
I'd put a manual toggle swith on the camera (you can tie into any switched 12 volts source, theres a switched single terminal in the fuse block available, or you can tie into the radio feed wire. Sometimes you want to see whats back there without having to put it in reverse.
Axle is offline   Reply With Quote
