10-02-2024, 05:43 AM | #1 |
Active Member
68 wiper motor gasket/seal
Had some rust damage on wiper motor hole in cowl. Ordered a replacement gasket from GMC Paul's. The hole on this gasket it quite a bit smaller than the original one. Are these made to cut? Am I missing something?
Joey |
10-02-2024, 11:50 AM | #2 |
Re: 68 wiper motor gasket/seal
I got one of those from GMCPauls and it fit just fine without any cutting.
10-02-2024, 02:26 PM | #3 |
Active Member
Does the lip that is on the hole in cowl press into the gasket?
Joey |
10-02-2024, 02:29 PM | #4 |
I don't know. I just bolted it up. It hasn't leaked.
10-02-2024, 04:08 PM | #5 |
Active Member
I will post a pic when I get home
Joey |
10-02-2024, 06:44 PM | #6 |
Active Member
Here is a pic of a piece of the old gasket lying on top of the new one. And another pic of the piece of old gasket in its original position on the wiper motor.
Joey |
10-02-2024, 06:52 PM | #7 |
Active Member
Here is a shot up under the dash, the non rusted part has a flange. All of the gasket was rotted out when we pulled the wiper motor. Ordered the gasket and built a piece to epoxy based on the pattern of the old gasket. This new one does not match the outline on the wiper motor from the old gasket in the previous pic. The gasket will fit the wiper motor, but not around this hole in the wiper motor mount.
Joey |
10-02-2024, 07:03 PM | #8 |
Will the new gasket fit around the rubber seal on your motor?
10-02-2024, 07:21 PM | #9 |
Active Member
yes
Joey |
10-02-2024, 07:41 PM | #10 |
The little lip on the cab mounting surface will likely just pierce into the seal, which may actually enhance the tightness of the sealing.
10-02-2024, 07:50 PM | #11 |
Active Member
That's what I was wondering. Used a compass and built a piece based off of the old gasket. Made it out of epoxy with the lip. It is strong but not sharp enough to pierce the gasket. Might just grind it flat and work from there.
Joey |
