10-01-2024, 11:26 PM | #1 |
AC/Cig Lighter and Accessory Wiring Question
Putting a half apart 1972 C10 Factory Air Truck back together. I was wondering if someone might know where the open terminal on the backside of the orange AC harness is supposed to plug-in I was thinking of utilizing it as a constant 12 V source for a clock I added, however I didn’t want to use it if it already has a factory purpose does anyone know what plugs in there? I have taken some photos and apologize they were at night, but you see the terminal which has a connector on it has an open mail plug inside of it. I have scoured my diagrams and can’t seem to find it anywhere what might go to it.
Yesterday, 12:16 AM | #2 |
Re: AC/Cig Lighter and Accessory Wiring Question
My 1971 has factory AC. Perhaps this may help. I won't swear by the anti-dieseling wiring, because I didn't install one. But I believe it came factory with one. This is how I understand it - see Blower Motor Relay.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Yesterday, 12:47 AM | #3 |
Amazing information, I definitely won’t be running that, so that just tells me I can steal that for a 12V positive source. I assume it’s also safe to say this is not a keyed 12V source as I assume the cigarette lighter always has power.
I would just test light it but the engine harness and front harness are not plugged in. |
Yesterday, 01:14 AM | #4 | |
A weak Positive plunger from some accessory plug [GPS, RADAR Detector, etc...] bent over on insertion and shorted across the Ground side of the plug barrel, and I had a big short/electrical fire under my dash. As soon as I smelled the ''blue smoke'' -- I pulled the Negative lead from my Battery. Later I had to cull out and replace a lot of charred wiring from other systems I had looped together in a bundle, trying to make the wiring runs under my dash look neater. Cheap insurance.
Yesterday, 01:19 AM | #5 | |
Yesterday, 01:36 AM | #6 |
Good. You're on top of the game.
Today, 12:48 AM | #7 |
Does anyone know if they make a pigtail that plugs into that or the harness for the anti-dieseling to steal the connector from.
Today, 01:09 AM | #8 |
Mostly Anti Dieseling Solenoids are tied into 12 DC in the engine harness, like electric chokes. Never heard of powering one off a Cigar Plug -- if I understood your query.
