Old Today, 08:12 AM   #1
bigd65
bigd65's Avatar
Temp guage rising
About 3 months ago I replaced waterpump, fan clutch, thermostat, hoses. Wednesday this started. The temp goes up to the tick between 210 - 260. It climbs to this but does not literally overheat. I open the hood, the fluid is correct and the motor area does not feel abnormally hot. If I leave it sit for a short time and start again. It will be at 210 mark and then rises again.
Im thinking Temp sensor. Any other ideas... oil is fine, fluid is new and fine... I work in the chemical plants and use my truck. I need my truck dependab
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old Today, 09:10 AM   #2
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Temp guage rising
I don't now squat about newer trucks but I would check the ground on the temp sensor, specifically if it was installed with teflon tape or some other sealant that would interfere with the ground conductivity. If not, put the sensor in boiling water and read the ohms across the terminals. There should be specs for a normal sender online someplace. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
