10-06-2024, 08:05 PM | #326 |
Re: The Doc & Kim 69 build
this week and weekend I was able to get the detent cable installed, core support mocked up install the radiator bend my SS trans cooling lines enough to get them installed proper. Last was the rad hoses seeing I set the motor rearward a bit I had to be creative with the stock top rad hose next couple days ill get some gauges hooked up temporary to monitor temperature and oil pressure I also hooked the fuel line to carb and fed the fuel pump from a gas can eureka
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 10-06-2024 at 08:07 PM. Reason: more |
10-07-2024, 09:03 AM | #327 |
Looking good! What radiator is that?
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
10-07-2024, 06:30 PM | #328 |
Which bender and flare machine are you using for the stainless line?
My 1970 C10 ChassisFab LWB to SWB Build Thread |
10-07-2024, 08:55 PM | #329 |
Eastwood flare and I have 2 benders I take some pics tomorrow
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
10-07-2024, 09:04 PM | #330 |
I bought this one on EBay back in 2021 looks like they are no longer available there are others similar though of course now for more $$$$$
3 Row Aluminum Radiator&Shroud&Fan&Thermostat Fit Chevy/GMC C/K 10 20 30 Pickup Delivered on Wed, Oct 27 Return Window Closed on Nov 26. 3 Row Aluminum Radiator&Shroud&Fan&Thermostat Fit Chevy/GMC C/K 10 20 30 Pickup US $215.00 Sold by: wzho31
10-09-2024, 08:35 PM | #331 |
hooked all the essentials today fired the engine off today sounds good oil pressure goord I need to clock the distributor tomorrow Im off a tooth you guys no the drill TDC exhaust valve intake valve in proper position ill get it then out with the timing light and let her run up to temp again I want to spin the trans not sure how to do that with no brakes I have not installed the drive shaft and have a spare drive shaft yoke inserted well that for another day
here you go https://youtube.com/shorts/QQH4x6e0i...7eDYgVTn42Rq1f
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 10-09-2024 at 08:45 PM. Reason: new link |
10-10-2024, 08:20 AM | #332 |
Sounds good Jesse, nice work
Should put some enthusiasm in your build
10-10-2024, 10:04 PM | #333 |
thanks Jim the journey will take me to the spring God willing
10-19-2024, 08:28 PM | #334 |
well today I messed with the timing moved the distributor a gear tooth fired the motor up timing light on it 6 degrees advanced and let it run up to temp again Im pleased with how it went... what's next ...starter needs shimming install battery box on the frame
10-21-2024, 10:04 AM | #335 |
Sounds great!
10-27-2024, 08:43 AM | #336 |
played with the throttle cable and kick down/detent bracket I like the way it turned out all aftermarket stuff except the accelerator cable so much easier with no fenders to lean over.....with my abused and old back
10-27-2024, 09:09 AM | #337 |
Nice neat. Work Jesse, I can almost hear it running from here
IMHO I would paint the spaces between the ribs on the VC Do you use spreader bars on them
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-27-2024 at 09:22 AM. |
10-27-2024, 10:19 AM | #338 |
I thought about it painting them I might do that …. Not familiar with spreader bar ?? Please school me
10-28-2024, 09:40 AM | #339 | |
Also they may not have been installed at the factory, unsure, there were two styles available, long and short I’ll see if I can find a pic
10-28-2024, 09:52 AM | #340 |
Thanks Jim Yes I now know what you are talking about those VCs did not come with them and I have had them on and off during my start up process I’m not sure if I’m going to paint engine color or engine bay color I’m going with stellar black metallic it’s on caddy’s here is a pic I found on the net some years ago it’s the classic look I’m going
10-30-2024, 10:14 PM | #341 |
tonight I layed out the cross sills and the bed strips so I could determine where the fuel fill will line up .....I want to put a round stainless fuel access hatch over the fuel cap IS 2.5 ROUND so I need like 4 inch access hole
ANY SUGGESTIONS ? I bought this Boyd welding fuel tank years ago used... never had fuel in it couldn't pass up the deal so I will make it work
11-02-2024, 08:59 PM | #342 |
I mocked up the rear stabilizer bar and the drop down battery box to make sure the cross sills for the bed and stabilizer all clear only wild card now are the bed side braces anyone have pictures or measurements I will look on line for some pictures
11-04-2024, 03:15 PM | #343 | |
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
11-04-2024, 08:01 PM | #344 | |
11-05-2024, 04:55 PM | #345 |
No problem. I found that fact out on this board as well.
11-10-2024, 10:06 PM | #346 |
drilled and bolted rear stabilizer tonight...ill drop it down for paint this week
