Old 10-06-2024, 04:26 PM   #301
raggedjim
raggedjim's Avatar
Re: Previous owner '68
So I decided I would do a leak-down test. I know, the results might be different if the engine was hot and fully oiled, but I did it anyway.
Test psi was 100psi and I did test both at top stroke and bottom of each cylinder.
Results were:
Cyl 1 top - 90%, bottom - 92%
Cyl 2 top - 84%, bottom - 88%
Cyl 3 top - 84%, bottom - 80%
Cyl 4 top - 90%, bottom - 90%
Cyl 5 top - 82%, bottom - 80%
Cyl 6 top - 86%, bottom - 84%
Cyl 7 top - 96%, bottom - 94%
Cyl 8 top - 90%, bottom - 90%
Now this was a long sitting, dry engine. Given the results I am going to replace the valve guide seals and hope for the best. If you think I'm screwing up let me know.
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 10-07-2024, 10:29 AM   #302
clay68c10
clay68c10's Avatar
Looking at how clean the valley is on that one, and your cold test results, I'd say it's a runner.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 10-08-2024, 09:36 AM   #303
raggedjim
raggedjim's Avatar
Too late, I couldn't resist tearing it down! I'd hate myself if I didn't.
Pics to come...
Roger
'70 GMC Jimmy 2wd
Old 10-12-2024, 07:17 PM   #304
raggedjim
raggedjim's Avatar
So, I pulled the heads. I decided to go ahead and put new head gaskets, valve seals, etc. Cylinder are pretty clean, no ridge at all, and still some crosshatch on the bores.
Tops of pistons have carbon, she was running a bit rich. The liquid is Marvel Mystery fluid I used to store engine for the last 20 years.
Roger
'70 GMC Jimmy 2wd
Old 10-12-2024, 07:19 PM   #305
raggedjim
raggedjim's Avatar
Cleaned tops of pistons with Aircraft stripper, not perfect, but it'll do. By the way, they are .030 over.
Roger
'70 GMC Jimmy 2wd
Old 10-12-2024, 07:23 PM   #306
raggedjim
raggedjim's Avatar
Main bearings and rod caps look good. I put them back with a bit of assy lube and torqued them down.
Roger
'70 GMC Jimmy 2wd
Old 10-12-2024, 07:25 PM   #307
raggedjim
raggedjim's Avatar
Crank looked good too.
Roger
'70 GMC Jimmy 2wd
Old 10-12-2024, 07:27 PM   #308
raggedjim
raggedjim's Avatar
Shop is kinda a mess while I'm doing all of this.
Roger
'70 GMC Jimmy 2wd
Old 10-12-2024, 07:35 PM   #309
raggedjim
raggedjim's Avatar
Wasn't going to pull the cam but I decided to so I could get some assembly lube on it. I also replaced the cam plug. Not sure what cam is in it. The end was stamped B040A and 891344 which I couldn't find anywhere on the web.
No pic of cam but here's one of the timing chain and the rear cam bearing.
Roger
'70 GMC Jimmy 2wd
Old 10-12-2024, 07:39 PM   #310
raggedjim
raggedjim's Avatar
Starting on the heads tomorrow. If all looks good I'll replace the valve seals, lap the valves, and reassemble them. They are nothing special, I just want a good running truck.
Roger
'70 GMC Jimmy 2wd
Old 10-12-2024, 08:39 PM   #311
zicc1835
zicc1835's Avatar
you got busy in a hurry ....nice progress
zicc1835 is offline   Reply With Quote
Old 10-13-2024, 04:42 PM   #312
raggedjim
raggedjim's Avatar
Thanks Zicc!
Finished tearing down the heads. I used a lever type spring compressor my uncle made to remove the keepers.
Clamped the heads down to my table and started levering the springs. Also used a magnetic pickup tool and a pick to remove the keepers.
If you're curious, the heads are 333882 on drivers side and 462624 on passengers side. The intake valves are 1.94" and exhaust is 1.5". Not the best heads, but they will work for me.
Roger
'70 GMC Jimmy 2wd
Old 10-13-2024, 04:46 PM   #313
raggedjim
raggedjim's Avatar
Tried my best to remove this broken exhaust manifold stud. Basically, an hour of dicking around with the welder. No bueno.
I'm going to take the heads to the machine shop to have them cleaned and the broken stud removed. Sometimes you gotta know when to let the pros do it.
Once I get them back I will lap the valves and reassemble.
Roger
'70 GMC Jimmy 2wd
Old 10-13-2024, 04:49 PM   #314
raggedjim
raggedjim's Avatar
Gonna need a new dampener. Unless you guys have an answer for this.
Roger
'70 GMC Jimmy 2wd
Old 10-13-2024, 04:51 PM   #315
raggedjim
raggedjim's Avatar
I also disassembled the oil pump out of curiosity. Looked good inside, looks like it is a Melling high volume pump.
Roger
'70 GMC Jimmy 2wd
Old 10-13-2024, 05:11 PM   #316
MySons68C20
MySons68C20's Avatar
I have used this repair kit with great success.
https://www.autozone.com/external-en...4121/76828_0_0
https://www.ebay.com/itm/12656266943...xoCy84QAvD_BwE
MySons68C20 is offline   Reply With Quote
Old 10-13-2024, 05:16 PM   #317
raggedjim
raggedjim's Avatar
Originally Posted by MySons68C20 View Post
I've heard of those, what is the process? Do you epoxy it to the snout?
Roger
'70 GMC Jimmy 2wd
Old 10-13-2024, 05:27 PM   #318
MySons68C20
The kit comes with a red Loctite type stuff....If you buy the bare sleeve I would use red Loctite.
Old 10-13-2024, 05:33 PM   #319
raggedjim
raggedjim's Avatar
Thanks!
Roger
'70 GMC Jimmy 2wd
Old 10-18-2024, 10:12 AM   #320
raggedjim
raggedjim's Avatar
Waiting, somewhat patiently, on the machine shop. I had to take the head in to have the broken bolt removed, all my efforts were fruitless. I figured I'd take both in so they could clean them, they do a better job than I ever could.
Roger
'70 GMC Jimmy 2wd
Old 10-21-2024, 07:28 PM   #321
raggedjim
raggedjim's Avatar
While waiting for the machine shop to finish cleaning my heads I decided to clean the TH350. What I started with, pretty dang dirty (which just happens to be my m.c. name).
Roger
'70 GMC Jimmy 2wd
Old 10-21-2024, 07:31 PM   #322
raggedjim
raggedjim's Avatar
A few cans of oven cleaner, a couple cans of barley pop, some degreaser, and a bit of salty language, and it is looking a bit better. I will be tearing this down and rebuilding (I need the experience).
Roger
'70 GMC Jimmy 2wd
Old 10-21-2024, 08:34 PM   #323
zicc1835
zicc1835's Avatar
wow... like it came from the factory
Old 10-22-2024, 09:48 AM   #324
loudchevy
loudchevy's Avatar
That is a lot of work to clean!
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 10-22-2024, 10:01 AM   #325
raggedjim
raggedjim's Avatar
Yes it was! Especially for something most people will never see. But it was so dirty to start I was afraid it would cause problems once I get inside of it.
The oven cleaner and pressure sprayer did most of the work but there was a bit of hand scraping for the heavier gunk.
Roger
'70 GMC Jimmy 2wd
