Old 05-02-2023, 07:38 AM   #1
mgkgmc
mgkgmc's Avatar
Electric fuel pump for cab tank?
Is it possible to add a fuel pump for the existing behind the seat original fuel tank? I purchased a 383 but I am not looking forward to redoing the whole fuel system over by adding an under the bed tank. Let me know if any of you have done this or is it just not possible. Thanks
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 05-02-2023, 08:40 AM   #2
nightrider388
Re: Electric fuel pump for cab tank?
There is someone on here that installed a mazda in tank. You can also do an inline (noisier), but the inline pumps have come a long way.
nightrider388 is offline   Reply With Quote
Old 05-02-2023, 11:55 AM   #3
my67c20
This is what I did for the inline pump that came with the Holley Sniper kit. Its a bit noisy at idle, but who really spends a lot of time at idle.
my67c20 is offline   Reply With Quote
Old 05-02-2023, 02:36 PM   #4
damnyankee36
damnyankee36's Avatar
I'm wondering if an in-tank pump would be any noisier than an in-line pump mounted on the frame rail with rubber mounts. Being right behind you a pump in the tank might be pretty noisy.
I have a Holley pump tank module in my Camaro and I can hear it.
damnyankee36 is offline   Reply With Quote
Old 05-02-2023, 02:54 PM   #5
jimijam00
In-line (external) pumps are a lot quieter nowadays. I've got one under the cab inside the frame rail.
jimijam00 is offline   Reply With Quote
Old 05-05-2023, 02:21 PM   #6
Mruss70
I have an external fuel pump on my 68 c10. It’s a little noisy when first starting but my exhaust drowns out the noise.
Mruss70 is offline   Reply With Quote
Old 05-05-2023, 06:17 PM   #7
RustyPile
RustyPile's Avatar
I bought my '71 in December of 2017.. A previous owner had removed the stock fuel pump and installed an electric fuel pump on the frame rail right under the passenger side seat. He removed all the steel fuel lines and fed fuel through a braided hose..
After about a year of listening to the WHINE of that pump, I removed the pump and all associated parts.. Took me a bit of time, but I fabricated new lines, including the return line, and installed a "3 line" fuel pump.. Best thing I've done for that truck..
If you like listening to an incessant screaming noise, get ready 'cause it's coming with an electric fuel pump...
RustyPile is offline   Reply With Quote
Old 05-06-2023, 09:00 AM   #8
LockDoc
The Older Generation
LockDoc's Avatar
I installed a pump out of a 2003 Chevy truck in my original tank.
http://67-72chevytrucks.com/vboard/s...=829820&page=6
Post #146, goes through #150. I haven't had it running yet so I don't know how it is going to work.
LockDoc
Leon
Old 05-06-2023, 08:03 PM   #9
diggerbob
diggerbob's Avatar
Can you install an underhood surge tank instead? https://www.summitracing.com/parts/fif-50006
diggerbob is offline   Reply With Quote
Old 05-06-2023, 08:57 PM   #10
jumpsoffrock
LockDoc
Hoping that it works, because that is a very clever idea, Doc.
jumpsoffrock is offline   Reply With Quote
Old 05-06-2023, 09:43 PM   #11
LockDoc
LockDoc's Avatar
Thanks.
LockDoc
Leon
Old 05-07-2023, 01:07 PM   #12
mgkgmc
mgkgmc's Avatar
LockDoc that was very informative some reason I would like to keep the tank I guess I like it somewhat original looking. I’m pretty sure I’m going to go this route. Thank you!
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
Old 10-10-2024, 01:46 PM   #13
502c20
502c20's Avatar
Hey doc
How did you route the wires out of the tank?
I'm thinking about doing that for my efi conversion
1971 c20 502ci b&m 420 4l80
502c20 is offline   Reply With Quote
Old 10-10-2024, 08:16 PM   #14
LockDoc
LockDoc's Avatar
Originally Posted by 502c20 View Post
Hey doc
I just drilled a hole in the top of the sender and ran them through there. I sealed the hole up with gas tank patching epoxy.
I have been driving the truck for over a year, with no problems so far.
Leon
Old 10-10-2024, 09:56 PM   #15
502c20
502c20's Avatar
Awesome thank you
Old 10-11-2024, 07:26 AM   #16
70STOVEBOLT
70STOVEBOLT's Avatar
How noisy is this? I would like to steal this idea.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 10-11-2024, 08:28 AM   #17
LockDoc
LockDoc's Avatar
I can't really hear it except when I first turn the key on because my hearing is so bad. My wife can hear it but she says it doesn't bother her.
I guess it would depend on how much errant noises bother you. Some people it doesn't bother and some people it drives them nuts.....
Leon
Old 10-12-2024, 03:03 PM   #18
Dashman
Active Member
my67c20
I did something similar with a Carter P4070. I think it's quieter than the Holley Red pump. I barely hear it. I wired it to an oil pressure switch. I like an electric pump for Holley carburetor adjustments. I just remove the fuse, idle the fuel dry in the bowl, and remove it with hardly any fuel spilt.
An electric pump, inside the tank, inside the cab???
If I get in a crash, I have to hope that the engine stalls for the oil pressure switch to turn off the fuel pump. Otherwise, I have fire danger with fuel being pumped outside my truck. What's to keep the fuel from a fuel pump inside the cab from spilling into the cab?
Dashman is offline   Reply With Quote
Old 10-12-2024, 11:40 PM   #19
Jrainman
Jrainman's Avatar
Had a outside rail fuel pump on initial EFI install , to much noise for me , so I cut a in tank fuel pump I had laying around from a Dodge in to the stock 72 fuel sending unit a couple of clamps a few inches of hose . then for the return I put a 3/8 bulk head fitting a few inches away from the sending unit ,keeping the return close to the sending unit hole is key so no metal shavings when drilling hole and also to tighten the bulk head fitting to the tank . overall worked very well , cut the noise down a ton , the only issue was slosh below a 1/4 tank on sharp turns , ran that for about a year before getting around to a rear frame tank install .
Jrainman is offline   Reply With Quote
